jc_is_the_man
- 40
- 0
- Jul 17, 2008
New hyde Park,
New_York
I recently completed a motor swap and while it was out swapped a PP and clutch disk with more meat on it. Now it will go into gear if I really force it too or if the car is off. The engagement point is extremely low and today when I went to adjust the master cylinder rod I ran into a couple issues. The system has been bled already by the way.
1. When I looked up a the master cylinder, I noticed alittle fluid on the boot. Not alot at all, but it looked alittel damp.
2. After watching the youtube vid with jack's trans clutch adjustment. He can manually compress the slave cylinder. I can't do this at all. I was screwing the master cylinder rod all the way out and was going to adjust it from there. But I'm not sure how much to adjust it out or in because of that.
3. Is it possible I screwed something up when putting the clutch back on?
4. I also noticed with taking it around the block the shifting was very hard. I had to force my shifter to shift. It wasn't smooth like it used to be.
Thanks for the help.
