GRNDSM
Moderator
- 2,417
- 174
- May 16, 2002
Chelmsford,
Massachusetts
So, there are numerous threads on how to do this swap, but I haven't seen this issue addressed:
What do you do about the convertible top neutral/safety switch? I am in the middle of the swap and need to put up the top, but it isn't working. I suspect that that safety switch which prevents you from lowering the top in gear is not working (shifter/tranny are all out at this point).
Where does top controller get this signal?
Even if I manually over ride the top, I will be all set for now, but eventually, I will have to figure this out.
Thank you,
Thank you,
