- Thread starter
- #26
stiggity99
- 231
- 4
- Mar 31, 2011
York Haven,
Pennsylvania
Note: This feature currently requires accessing the site using the built-in Safari browser.
TPS is still jacked, DA fuel table is still too rich. Same sh**, different log...
http://www.dsmtuners.com/threads/98-gsx-is-the-tune-looking-any-better.512044/#post-153649164
If you don't take the advice we give you and actually use it to make changes to your tune, I'm not sure why you bother to keep asking for help. My patience has run out here.
doubleclutch:
I fixed the issue where it was knocking at 5500rpm. I separated all EMS electronic clips, inspected and cleaned each one. Here the starter ground wasn't connected to the starter, it was just attached to the trans, not the engine block. I also remounted my MBC , MAP sensor.. .this is GREAT!!! now, as GST with PSI said a year ago.... add boost and timing to your taste.. NICE!!! I was feeling so sh**ty about my car for 2 weeks, I was almost convinced to part it out!!!! I'm running Sunoco 93 10% ethanol
