xnevermorex
- 0
- Apr 15, 2017
Anderson,
Indiana
I have a 98 Eclipse GS 2.0l non turbo. Just flushed the cooling system because previous owner had dumped fresh oil in the coolant reservoir. Since then, about 2 weeks, I have had to add another gallon of water. I noticed a little water coming out the tailpipe and white smoke. I'm figuring that the head gasket is blown or it has a cracked head. Hopefully it's just the gasket. Is there anyway of changing the head gasket without removing the engine? Or can I just drop the engine and cradle on the floor and jack the front of the car up? The reason I ask is because there are bolts on the front of the engine i can't get out cause there is not enough clearance between the front of the engine and passenger side wheel well.
