Please Support Morrison Fabrications
Please Support STM Tuned
'97 GSX
Completed build
Engine has been modified with a stage 2 short block, 1 mm oversize valves, 272 crower cams, custom mounted front mount intercooler that allows retention of factory fog lights and custom made grill in the bumper. Oversize injectors, oversize fuel pump, gm 3.5 mass airflow sensor, larger tho5h 20g turbo with exhaust header and custom made fully welded 3" exhaust. Engine has adjustable fuel pressure regulator with custom anodized fuel rail, one off powder coated valve cover, front and rear strut tower conectors. Custom stereo system with double din touchscreen radio, amp,crossovers and subwoofer in a custom made box in place of the spare tire. High performance axles front and rear with cross drilled rotors. Car is custom black in color with gray hand air brushed flames and a hand painted lime green mitsubishi emblem and laminated iridescent green headlamp covers
