Jay 97 GSX
- 43
- 6
- Jul 11, 2017
Joliet,
Illinois
Good afternoon guys and gals.
I just purchased my second DSM, my first was a 95 eclipse gst auto, and i have my first GSX manual.
I paid a very nice price for the GSX about 1500$. strut tower rust ect. The motor runs very healthy, no Smoke and turbo spools and the trans shifts perfect 1-5th gear, no grinds or pop outs.
The problem I'm having I believe is the transfer case. When i purchased it i noticed a large spot on the ground under it and it was directly under the T-Case. I smelt it and it smelled just like Gear Oil, that nasty weird oil smell.
While the car is Moving with the gas pedal engaged, it makes a horrible grinding noise coming from the Bottom of the car, i believe from the t-case. I was able to make it home and park it. I believe its grinding because it has no Gear oil in it.
When you let off the gas the grinding goes quiet, or even when u put it in neutral the grinding goes real quiet but its still there.
I just hope its the t-case and not the center Diff. Has anyone ever had this problem with the t-case?
Since it drove home on a 20 minute cruise 40mph and under, am i safe to try to add fluid and see if it still grinds or just Remove the tcase. I debated removing the tcase but im unsure what im supposed to check for on a working tcase.
