Please Support Kiggly Racing
Please Support Rix Racing
For Sale 96 gsx shell
mario009
194
May 19, 2005
reno, Nevada
Lake tahoe text for fastest response 5302107452
1996 gsx shell full interior and exterior PLUS extras-2500$
Can come with the tein coilovers and evo 8 wheels, the turboback exhaust other wise price can go down with stock suspension and different wheels and no exhaust . 87k miles on chassis and 4k miles on parts. Clean nv title, 2gb conversion with black and grey leather interior, stereo, it even has the stock rear cargo net. Near mint interior. No a/c ,fog lights,battery, EGT,Boost and narrow band gauges with the pillar pod,short shifter, greddy shift knob,Symborski Shifter bushing Kit,RMDSM Front + Rear Sway Bars, Ingall Front + Rear Camber Kit, complete head with valve cover, tcase,complete wiring harness,complete rear end, Driveshaft,stock radiator with fan, fmic with piping, intake manifold, fuel rail,walbro 255 pump, turbo timer, stock exhaust manifold, 2g maf, air intake pipe, act clutch and flywheel included (spare I had) 6 bolt crankshaft, stock ecu,basically will just need a block and turbo, injectors,transmission and your good to go. This is one of the cleanest 2gs I've ever owned, no rust.
Apexi N1 catback, RRE downpipe, High Flow Cat-600$
New slowboy racing short route fmic-600$
J-Pipe-30$
Stock 2g bov-25$
Hks bov-150$
FIC 650cc fuel injectors-150$
135 Amp Alternator-
Prothane inserts-
Air intake-75$
Fludyne aluminum radiator-200$
Engine:
All machining, balancing, and assembly done by previous owner who was working for nismo in japan or something, his name is nathan alloy,i have his email so u can confirm with him)
6bolt block, Ross 20 over pistons, Scat Rods, Clevite Bearings, Rotating assembly balanced with the Pressure Plate/Flywheel. ARP main studs + rod bolts.-$1500
2g Cams MT Turbo Cams - Polished. Arp head studs,stock 7 bolt head-500$
Fp race manifold-150$ 200$ with hardware and gaskets
Engine Management:
Autometer Gauges: Air/Fuel ratio, Boost/Vac, and Exhaust Gas Temperature
Profec B boost controller-150$
3.5 Inch GM Mass Air Flow sensor with maft translator-150$
Techedge 2B0 Wideband O2 sensor kit-150$
Drivetrain:
TRE stage 2 transmission with 4 spider diff -$1500
ACT 2600 clutch with fidanza flywheel -300$
Driveshaft Shop's Stage 2 Axles front-400$
three speed scatter shield-125$
Handling:
Tein Type Flex Damper coilovers-700$
RRE Rear Strut Bar-50$
I have a lot of other parts this is just one ad.
