Ernie D
- 73
- 1
- Aug 25, 2012
Westlake,
Louisiana
I'm wanting to share my progress on my build up, I recently purchased my TSi about 2 months ago for $500 from a buddy of mine.
When I got the car I checked it out, it had no oil pressure and a low end knock, I pulled the whole sub-frame out and noticed quite a few bolts and a few bushings missing, so I figured perfect time to fix shit right.
The car already had a few upgrades done to it such as, a wally 255, yellow top 510cc injectors, a EVO II Big 16G, FMIC, a 6-bolt conversion, ARP head studs, fridanza flywheel with a ACT clutch, ECU chipped, Apexi SAFC and a AFX wideband
I pulled the engine apart and found my issue for no oil pressure, the balance shaft bearings had spun. ( please excuse the pics, my phone did a upgrade and I lost a few pics and others did this )
I started rebuilding my engine back up, I've done a BSE, added ARP rod studs and Mahle pistons with the stock 6-bolt rods, I'm using cometic gaskets, I built up a 2g head to use instead of the 1g head
My plans so far still is:
Trying to find a EVO III intake to use or use a 2g intake and porting it out to use a 1g throttle body
I have a set of racetronix 930cc fuel injectors to use instead of the yellow tops
I'm currently upgrading to fuel system more with AN-6 fittings and stainless line
also rewiring the pump
I plan on setting up DSMlink with speed density
The A/C was stripped out under the hood but I'm wanting to reinstall it, it gets hot here, gotta have a little creature comfort
I'm thinking about upgrading the clutch a little more with a stronger pressure plate and 6 puck disk
Any comments or suggestions are welcome
10/11/2012
Hey guys, I haven't forgot to post anything on here, just been working ALOT lately, (2 unit outtages where I work) I've gotten a few more things done.
I've got a set of HKS 272's from a buddy of mine that decided to sell his project, been cleaning and painting parts before installing on the engine
Still on the lookout for a EVO III intake, a 97-99 GSX complete A/C bracket
Thinking about sending my header,turbine housing, and O2 Housing to Darren at FFWD Connection to get Stage III CGB-1000 coatings done to them, any advice on that?
Gathering fittings and other parts to upgrade fuel system ( AFPR, and AN-6 fittings and fuel filter )
I will post some pics soon, later
10/20/12
A little update, progress is slowly going along, got a few things bolted up on my block, I found I now have a issue with my turbo, I didn't check it as close before than I have now, I have to rebuild it, it has a little too much play in it than what I think it should.
Also I was gonna use the header that I have BUT, also checked it out a little more, its a little warped on the flange to the head. I'm debating to buy a new header or between buying a EVO III manifold from RRE or buy a FP manifold, anybody to advise on this?
Here's a few pics of progress
10/11/2012
10/20/12
