Moonlight GSX
- 553
- 49
- Nov 16, 2010
Hagerman,
Idaho
Well as the title states this is the road to producing a car that will be come the most awesome weekend warrior my money can buy, yes that means it'll take some time as I'm broke. Anyways this isn't about me it's about the car well right now the only thing in the works is the engine and suspension but I'll have more pictures once the car has been shipped to the UK as right now my home-station is over here so yeah it'd be good to get it here so I get the work really started.
Currently this is what I plan to do - this is tentative only because things change and well know this but here's "The List."
1995 Eclipse GSX Mod Listing
Engine:
1. 97-99 7-bolt (Thrust Bearing) short block
a. Manely DIY Rotating Assembly 7-bolt (Evo 8/9)
i. Thrust bearing
ii. 100mm stroke (stock 4G64)
iii. Manley Turbo Tuff Beam w/ ARP 2000's
b. Block Machining – The Works
i. Black
ii. Sending Core
2. 95-99 Stage 4 Custom Built Cylinder Head
d. Kiggly Beehive Springs and Retainers
e. Supertech Bronze Magnesium Valve Guides – Precision Honed
f. 272 Kelford Cams
g. 95-96 Cam Sensor
h. AEM Tru Time Cam Gears – Black
i. Stage 2 Porting
j. 1mm Oversized Valves
k. Send Core
Fuel System:
1. STM -6AN Fuel Tank to Rail Kit
a. Black Fuelab Filter
2. STM -6AN Fuel Return Kit
a. Black Regulator
b. Standard Regulator (-10AN inlet/-6AN outlet)
3. FIC Blue Max 1350cc Fuel Injectors
4. Walbro 255lph In-Tank Fuel Pump
5. Walbro 255lph In-Line Fuel Pump
6. –AN to Barbed Fitting adapter (to be modded to fuel hanger)
a. -6AN (black) – send line
b. -6AN (black) – return line
ECU:
1. DSMLink V3 (FULL)
Exhaust/Turbo System:
1. 3" Custom Downpipe
2. 3" High Flow Catalytic Converter
3. Megan Racing 3" CAT-Back Exhaust System
4. Garrett GT4088R Turbocharger
a. T4 Divided .85 A/R
b. T04S (4" Inlet/ 2.5" Outlet)
5. STM Proclassic Oil Return Kit
a. GT Series Turbo
b. Oil Return Kit 95-99 (Proclassic)
6. ARP Turbo Bolts
7. JHR Racing Divided Twin Scroll T4 GT40R Exhaust Manifold
8. TiAL V-Band Wastegate (x2)
a. MV-S 38mm
b. MV-R 44mm
9. Manual Boost Controller
10. Wideband UEGO Sensors/Gauges (for accurate AFR reading)
11. Oil Feed/Drain Setup
a. Oil feed-line kit w/ 15 micron filter (head location) 90-99 Eclipse - Extreme PSI
b. .035 restriction fitting
Intake/Intercooling System:
1. Extreme Turbo Systems FMIC
a. HKS Blow Off Flange
b. T3/T4 w/ 2.5" Turbo Outlet
c. Powder Coated Flat Black
d. Speed Density
i. ECM Tuning Speed Density Plug n' Play harness
ii. SD Bundle (MAP, IAT, pigtails and bung)
e. 3" Intercooler (thickness)
f. No ETS stencil
g. Include 2x – 2.5" to 3.25" Transistor Couplers
h. No Anodizing
i. Black Couplers
2. JM Fabrications "Street Version" SMIM
a. 1G '90 – '94 Throttle Body (required)
Drivetrain/Transmission
1. T.R.E. Stage 3 Transmission
a. Clutch Fork
b. Throw-Out (T.O.) bearing
c. Slave Cylinder
d. OEM Gear Ratios
e. Single Synchro 1st, 3rd, 4th, and 5th gears
f. Double Synchro 2nd gear
g. Gear detail
h. Torrington bearing upgrade
i. High intensity shot peening of gears
j. T.R.E. 4 Spider centre differential
2. Driveshaft Shop
a. Aluminum Rear Shaft (650HP)
b. Level 2 (650HP) Front Axles
c. Level 2 (650HP) Rear Axles
3. Transfer Case
a. Trade in old core for new/rebuilt transfer
4. Rear Differential
a. JDM EVO-III Limited Slip Rear Differential
Brakes, Steering, and Control
1. EVO-VIII Calipers
a. 4-piston front
b. 2-piston rear
2. Goodridge SS Brake Lines
3. Drilled/Slotted rotors
4. JDM Galant Legnum front knuckles (160mm spaced bracket)
5. MasterPro Front Hubs
6. OEM Rear Hubs
7. OEM Rear Control Arm w/ ball-joint (DS/PS)
8. OEM Rear Trailing Arm (x2)
9. OEM Front Lateral Control Arm (DS/PS)
10. OEM Lower Front Control Arm (DS/PS)
Some of this has already been gotten but it's a work in progress, keep tabs this should be good.
Got the block painted - lookin' good so far! Still need to clean out the oil/coolant ports due to the bead blasting to remove the previous rust that was on the block... (bead blast and powder coat completed by Sakura Motors in Pennsylvania).
Engine:
i. Thrust bearing
i. Black
ii. Sending Core
f. 272 Kelford Cams
g. 95-96 Cam Sensor
i. Stage 2 Porting
k. Send Core
Fuel System:
a. Black Regulator
ECU:
a. GT Series Turbo
6. ARP Turbo Bolts
a. MV-S 38mm
b. MV-R 44mm
d. Speed Density
f. No ETS stencil
h. No Anodizing
i. Black Couplers
a. Clutch Fork
c. Slave Cylinder
d. OEM Gear Ratios
g. Gear detail
2. Driveshaft Shop
3. Transfer Case
a. 4-piston front
b. 2-piston rear
6. OEM Rear Hubs
