1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G 95 and 98 transmission differences?
Posted by v8s_are_slow, Jul 7, 2018
Please Support Ace Race Parts
  1. v8s_are_slow
    v8s_are_slow Proven Member
    2,155
    53
    Joined Sep 30, 2002
    Panama City, Florida
    I have a 95 transmission in my car but have a 98 transmission sitting in my garage that a friend of mine gave me. It has double syncros, welded diff, etc. in it but I know you can't use a 98 transmission with a 95 transfer case because of the gear ratio differences. So I'm just wondering which parts are different exactly? My transmission is leaking and figured if I just took out the parts from the 98 that won't work, that'd be awesome. I also have 2 stripped bolt holes where the transfer case bolts up on my 95 so only have 3 bolts holding on the transfer case so wanting to use the 98 housing with the upgraded internals, and take my 4 spider diff out of my 95 and swap over to the 98 as well if that will work. Anyone able to help with some knowledge in this area? Thanks!
    Log in/Register to remove ads
    1998 Mitsubishi Eclipse GST
    10.949 @ 129.77 MPH
    Loading...
    Featured Products from our Supporting Vendors
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    3,273
    1,093
    Joined Nov 14, 2013
    Independence, Kansas
    Here is some information worth reading:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  3. pauleyman
    pauleyman DSM Wiseman
    4,824
    837
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    If you didn't quite get that change the front diff ring and pinion. I run a 96 trans in my 97 with a 97 transfer case.
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
    1990TSIAWDTALON likes this.
  4. 1990TSIAWDTALON
    3,273
    1,093
    Joined Nov 14, 2013
    Thanks Paul! I can give the info but you definately have the hands on experience to give him solid advice. I can always rely on your posts!
    Street Build
    14b   automatic
    Loading...
  5. v8s_are_slow
    2,155
    53
    Joined Sep 30, 2002
    Thanks! I'll just have to tear it apart and figure out exactly which parts those are. Lol. I've torn them apart plenty of times but it's been awhile now, thank the Lord!!!
    10.949 @ 129.77 MPH
    Loading...
  6. twicks69
    twicks69 DSM Wiseman
    3,170
    578
    Joined Mar 12, 2004
    Milwaukee, Wisconsin
    The front diff ring gear is the difference, the pinion gear is identical, that is, if no one else has swapped them earlier in its life. Either way, it is easy to identify.
    Ring gear has 58 teeth in 95-96, 57 teeth in 97-99.
    Transfer case differences is 1.090 ratio 24/22 tooth gearset for 1990-1996, and 1.074 ratio 29/27 tooth gearset in 1997-1999.
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
    v8s_are_slow likes this.
  7. v8s_are_slow
    2,155
    53
    Joined Sep 30, 2002
    Finally getting to this. Assuming these are the parts I need to swap out? 20180810_215418.jpg
    10.949 @ 129.77 MPH
    Loading...
  8. twicks69
    3,170
    578
    Joined Mar 12, 2004
    Correct. Count your ring gear teeth. The pinion should be identical in your circumstance, but check the tooth thickness and profile against the other one. You can also spin test the pinion vs. the front diff ring gear by hand and you will hear a noticeable chatter if you have the wrong profile installed.
    Drag Race Build
    9.499 @ 155.00 MPH
    Loading...
  9. v8s_are_slow
    2,155
    53
    Joined Sep 30, 2002
    Thanks! Got it!
    10.949 @ 129.77 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
