1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
95-96 eclise gst engine in 97 eclipse gst.
Posted by DSMgirl15, Mar 12, 2018
  1. DSMgirl15
    DSMgirl15 Probationary Member
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    Hi Im new to the forum, having some troubles with my engine swap. So I bought a 95-96 eclipse gst engine for my 97 gst (my husbands mistake). We have it all hooked up but it wont start up. It just cranks but wont turn over completely. I have been reading some about the cas being different? Im not sure what to do to make it work with my 97 wiring harness and ecu. I feel like that might be the issue, maybe somehing needs to be modified and I don't know what it is. Please be nice like i said im new to this. My main dsm fanatic is no longer around for me to get help from. If you need more info about anything to direct me in the right direction just let me know.
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
  2. lasershark
    lasershark Proven Member
    1,134
    209
    Joined May 17, 2013
    over yander, Idaho
    You can do two things, use a 1g cas or the 97-99 cas. Or you can extend the wires on the harness for the CAS and get a pigtail for the 95-96 cas.
    If you run the 95-96 style cas you will need to swap injectors and spark plug wires if you done have ecm link since the 95-96 cas will invert the injector and spark signal. (with ecm link you can just click a button)
    https://www.ecmtuning.com/wiki/swapplugwires
    My DSM:
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
  3. lasershark
    1,134
    209
    Joined May 17, 2013
    over yander, Idaho
    No. swap the order. So cylinder 2/3 wires become 1 and 4. And 1 and 4 go to 2/3. That is only if you use the 95/96 CAS. If you click on the link I posted there is helpful info and pics.
    My DSM:
    16g   manual
    Loading...
  4. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    Sorry misunderstood what you were saying. So just to make sure i understand properly. So if i use the 95/96 cas with the 97 ecu i swap the order? I hope i got that correct i did look at the link just want to make sure i understand properly. Since its talking about using ecm link.
  5. lasershark
    1,134
    209
    Joined May 17, 2013
    over yander, Idaho
    Correct.
    It's still helpful info as it explains the CAS invert signal. And if nothing else, pictures are helpful. ;)
    My DSM:
    16g   manual
    Loading...
  6. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    So i dont need to buy anything to modify my 97 ecu? Just switch the wire order.
  7. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    Thank you for you help and the link, i appreciate it.
  8. lasershark
    1,134
    209
    Joined May 17, 2013
    over yander, Idaho
    That's correct. Don't forget injectors too.
    Do you still have the 97+ engine?
    So just to confirm... You are going to run the 95/96 CAS that came with the motor?
    If so, then yes, swap injector pins at ecu and swap spark plug wires 1/4 is now 2/3, and 2/3 is now 1/4
    Are you going to get an adapter or wire in a pigtail?
    My DSM:
    16g   manual
    Loading...
  9. pauleyman
    pauleyman DSM Wiseman
    4,749
    812
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    Why didn't you just use the electronics from the 97? The physical motor and head should've allowed that. Now 97 in a 95 96 different story. I don't think the head has a cas provision but in your situation use the 97 cas if you wish.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  10. chrysler kid
    chrysler kid Proven Member
    1,554
    368
    Joined Dec 20, 2002
    Mckinney, Texas
    It's a can of worms, liks how when doing the engine swap they would have noticed the cam sensor had nothing to plug into.
    So there's that
    Loading...
  11. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    Yes im using the 95/96 cas right now. I do still have my 97 engine. So how how would i switch the pins for the ecu? Also what would i need to do to just use thr 97 cas instead?
  12. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
  13. chrysler kid
    1,554
    368
    Joined Dec 20, 2002
    Mckinney, Texas
    So..
    My point was that the connector for the cam angle sensor on the 96 engine is on the driver's side behind the cam cover, and that the plug on your 97 harness is on the passengers side by the throttle body. So you would have had to extend the wiring to plug the cam sensor in.
    So take the wires you cut and extended, and swap the colors around on the connector. You don't have to do it at the ECU
    Basically the 96 cam sensor is mounted under the cam, and the 97+ is mounted over the cam. So you flip the signal to let your 97 ECU see the cam through the upside down 96 sensor.
    Since this seemed new to you, I doubted whether your cam sensor was even plugged in since they are not close from a 96-97
    Loading...
  14. pauleyman
    4,749
    812
    Joined Nov 19, 2011
    I don' know why you wouldn't just use the 97 cas instead unless the cam won't take it
    My DSM:
    Street Build
    T25   manual
    Loading...
  15. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
  16. DSMgirl15
    10
    Joined Mar 11, 2018
    Saluda, Virginia
    Quick question i don't know much about re wiring. You said switch the colors around on the plug, what order do i hook them up?
  17. chrysler kid
    1,554
    368
    Joined Dec 20, 2002
    Mckinney, Texas
    Heh
    This isn't the newbie forum. The best way to find an answer is to get onto Google, and search for key terms. So for example, Google 95 cam sensor wiring site:dsmtuners.com will display all search results for this website. Which answers your question in the thread below
    Basically the wires are the same color, connect them the same color to the same color, then swap the plug wires on the coil
    http://www.dsmtuners.com/threads/cam-angle-sensor-question-95-engine-in-a-97.340349/
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
