6772owner
- 86
- 1
- Apr 2, 2009
Brighton,
Colorado
Hello everyone, this is my first build on the forum, been lurking around for many years though. A little background on me, I was bitten by the DSM bug about 12 years ago when I met a mutual friend that had a Talon TSI AWD, one ride w/boost and I was hooked! Apx 2 years later I scored my own Talon AWD (1GA), that I picked up cheap (a mutual friend had a wrecked car I rebuilt). I unfortunately had to sell the car shortly after getting it back on the road and vowed I would return someday!
That day came about 10 years later... I recently traded my current car for a 93' Talon TSI (FWD), 83,xxx on the shell, includes two engines and many other extras. The car had the engine pulled (stock engine was damaged years ago) but came with a Slowboy Racing complete engine (I believe it is a stage II, TBD)
Plans are to put the car back together and get it running with what I have, then mod/upgrade from there.
Here are some pics from picking up the car.
List of current parts I have found/dug out so far:
ECM link kit (cable, CD, socketed ECU, etc)
Dejon Tool short runner SMIM
Dejon Tool I/C piping for SMIC
Crushed factory BOV
GM MAF w/correct pigtail from ECM Tuning
Near new 14B (clean, no shaft play)
Braided turbo oil feed line and return line
DNP tubular manifold
3 different valve covers (polished, Hyundai & OE)
Clear & stock upper timing cover
Aeromotive FPR w/braided line kit
Poly engine/trans mounts
Wally 255 pump (rewired)
Battery Relocated
3" Downpipe
Aftermarket 3" cat
2.5" Pacesetter cat back exhaust
Leather interior, clean carpet and all intact
AWD front calipers (dual piston)
Braided Clutch line
Aluminum Flywheel w/new stock clutch
Slim aftermarket fans
Good all season tires on OE wheels
Coil-On-Plug Conversion
Custom air intake
SBR Engine has Kelford 272 cams, Greedy Cam Gears, Dayco HD T-belt
Manley valve springs (TBD)
H beam rods (TBD)
New tensioner, idlers, water pump, etc
BSE kit
More to be discovered/determined
Here are some more pics from picking up the car...
I also need some help identifying what injectors I have, do the numbers on them correlate to the seize/CC's? Here are the pics..
I would just like something close to stock, I can put whatever size into Link, so it shouldn't matter, I'm just worried about the impedence...
Crushed factory BOV
Battery Relocated
3" Downpipe
Aftermarket 3" cat
Braided Clutch line
Custom air intake
H beam rods (TBD)
BSE kit
