TsiTom
Supporting Member
- 8
- 0
- Jun 27, 2005
Fargo,
North_Dakota
1993 Eagle Talon TSi AWD Shell/projectVIN:4E3CG64F1PE024257
Miles: 134K
My house has become an ongoing project. I’m sick of seeing this project sit around and collect dust.
The car will not come with an engine. It will come with basically everything else.
The ECU has ECMLink V3 already installed (Cable/CD obviously will be included)
Issues:
-Suspension (struts/springs) are shot.
-Driveshaft will need to be rebuilt.
-Transmission works fine for daily driving. 3rd gear grinds when you put power to it.
-LH fender damaged from door coming into contact with it (see pictures)
-Tires have good tread but are 10 years old.
The car itself is rust free. It originally was a Texas car until the early 2000s…I bought it in 2005. The car saw 3 winters in my possession…Otherwise it was in a storage unit of under a car cover.
You will have to provide a way to tow it/trailer it away.
The following parts will come with the car. All are BNIB.
-Mishimoto aluminum radiator
-Mishimoto slim fan/shroud kit
-Innovate wideband o2 kit + gauge
-RM Racing 15/16” rear sway bar
-Stop Tech slotted front brake rotors
-Stop Tech slotted rear brake rotors
-Hawk HPS front brake pads
-OEM rear brake pads
-Walbro 255LPH fuel pump with install kit
-Energy Suspension front subframe busing kit
-Energy Suspension front sway bar bushing
-Energy Suspension front lower control arm bushing kit
-Energy Suspension rear lower control arm bushing kit
-Polyurethane rear subframe bushing kit (RTM Racing)
-Torque Solutions solid shifter base bushings
-OEM Non-cruise throttle cable
-OEM slave cylinder
-OEM inner tie rods
-OEM rack and pinion bushings
-SS Lower clutch line
-New front axles (RockAuto)
-New Starter (Rockauto)
$1700 (firm) for all of it
PM me with questions or if you’re interested!
Located in Moorhead MN
