Please Support JNZ Tuning
For Sale 93 GSX Eclipse No Spark 102k *on body* $1200
zachsEVO3
169
Apr 1, 2008
Ithaca, New_York
Currently non running due to no spark- coil pack was replaced so likely just the Ignition Control Module. No spark on cyl#3 I replaced it with a rock auto unit and it ran fine for like 1 afternoon then no spark across the board. Throwing my hands up.
4 bolt VLSD rear, black leather interior 102,896 mi on the body
The Mods: Engine bored .020 over, 3 angle valve job
ported evo3 exhaust manifold and ported downpipe.
50 Trim turbo, Mitsubishi hotstide internally gated- An early ball bearing GT3076R with about 2k miles on it.
Denso 660cc injectors
DSM Chips ECU programmed for 660 injectors, no speed limiter etc...
GEN 2 Mas Airflow translator hidden in amrest, GM LS MAF
Fuel Lab adj fuel pressure regulator with AN lines
Dejon Super sidemount intercooler with Dejon intercooler plumbing
Mildly rebuilt transmission sourced from dsmtuners member
RM beefy rear swaybar, KYB AGX dampers, Tein srpings
2G OZ anniversary edition alloy wheels
DBA front slotted rotors w ceramic pads front/ rear
Goodridge braided steel brake lines
Kartboy shifter bushings
(faded) VIS carbon fiber hood
Hella Black Magic 1000 ally lights
Tinted glass all around
The paint (Jaguar's British Racing Green)/ ext is the most worn thing about this car, basically everything else has been replaced. Extensive service record spanning all thee owners to 1998.
Not really moving on the price. Now that its warm I will try to get it running again, meaning the price would go up. As is you'd need to bring a trailer...
