9!'clipseDOHC
Moderator
- 4,906
- 452
- Aug 24, 2003
El Paso,
Texas
Subscribed Matt. Good luck getting her fixed!
Note: This feature currently requires accessing the site using the built-in Safari browser.
No. It ate those lifters because of one of two reasons. The "how to" i followed to install the lifters said you could just soak them in oil for a few hours and not have to pump them, thats how i used to do it. I'm starting to think thats why they all went. Originally i thought it was due to the increased lift of the reground cam i was running at the time, but im running the stock cam right now so thats not the issue.You don't think it broke for the same reason you were eating hydraulic lifters?
I know you don't want to hear it but that chassis is coming apart at the seams. I can't believe you don't feel any vibrations, there's nothing holding the strut towers to the actual chassis. I would seriously consider finding a good shell, how hard can that be and how safe would it be to drive the car rigged up the way it is or even with a patched up strut tower? It's great that you're thinking outside the box with your project (turbo 4g37 etc.) but I don't believe that car is any longer streetable.
Believe me, I don't want to be negative but I felt obliged to tell you. Good luck.
I'm looking at the Garrett GT2860R for my car. I'm wondering if this would be a good choice or do i need to go for a smaller one. I hope to get a good even range of power from my engine with decent torque.
Well with the stock cam, reving past 5.5k is a little pointless, as the power starts to fall off at that point. With that said, try and find a turbo that will spool early and have enough juice to hit 5.5k. A 13g or a t25 would probably be a good choice.
Did a little more research on some more Garrett turbos. How about the GT2554R. I don't know much about the pressure ratio but for where i'm at its about 1.9. I wouldn't want to go over 20 psi. Would a reground cam to 6k work better? I did get the "Garrett Boost Adviser" app that helps calculate pressures and what turbos are recommended in hopes that this would narrow the selection. Now being that the trim on Garrett turbos are relatively big would that mean that these turbos are too big? What other brand would you recommend? I do hope to do the same mods you did on your motor. Thank you for your help.
K. I was thinking about having a custom made header for putting on my turbo. I will try to find a smaller turbo for faster spool time. Do you recommend eBay for finding the Mitsubishi turbo? I don't have ac on my car anyways so that's shouldn't be a big problem with moving some things around for heat protection. Have you tried to make your valve ports bigger to increase VE and air flow? Just wondering if that's possible or not.
But on another note, your lucky to even be alive. Thats probably the worst damage to a car iv ever seen without the person being dead.
