xethur
- 0
- Apr 21, 2012
erie,
Pennsylvania
quick stats. 92 84k miles with no rust. Its a TSI so turbo and awd and a 5 speed to boot. I posted pictures on Photobucket. Since I'm on my tablet I can't seem post pictures directly to the thread so I'll post the link.
Pictures by xethur23 - Photobucket
The car was fairly unmolested when I bought it but I have fixed a few issues so far. I removed the glow shift boost gauge. It was mounted right behind the steering wheel and the 7 different color LEDs were just to much for me. I mounted a proper autometer boost gauge on the left side of the dash. Still waiting on a pod for that. I unrouted the MBC that wasn't actually hooked up. Someone ran a line into the cabin and hooked one side of of a $10 ebay MBC. I pulled the sub and amp out of the trunk and rewired the rear speakers. I don't have enough trunk space at it is. At least the stereo and speakers are name brand and wired in correctly. The 12v outlet was rusted so I pulled that out and used the stock wires to hook up a 3 way out let in the glove box. I'll take pictures of that when I have a chance. Added cup holders seeing as I wanted both an arm rest and cup holders.
So onto the good stuff. I decided to keep the 3" exhaust but PA requires emissions so I bought a 3" in/out catco cat and a 3" thursh muffler and had an exhaust shop weld them in. Once again I'll take pictures soon. The 3" nets me 14 PSI of boost which is fine with me. I've been fighting an idle problem that I have narrowed down to the FIAV at this time. When I get a chance I'll get in there and block that off and clean the intake / TB. I blocked off the EGR in my trouble shooting of idle. I used two nickels and RTV so the EGR looks unmolested and I'm plan to leave it that way. Since the exhuast ended up being too loud (big surprise) I added some sound deadening, well actually it is roofing material. To dispelled some myths, it does not melt and run and it sticks well. I was actually using a lighter to heat sections to make them stick better. Like you can do with duck / electrical tape. I'm still waiting on more sound deadening material from summit but so far just the roofing material has made it much less annoying to drive.
I have a long list of plans for the car but I'll get into those next post. Any questions are welcome.
So I promised to talk about upgrades. My goal is 300-350 HP. That's enough that I'll be able to eat most V8s but not enough to make her undrivable. From the lurking / research I have done I plan on a 16g and 272 cams. Yes there is a whole list of supporting mods involved with the 16g, so I'm looking at 650 injectors, 255LPH fuel pump, intercooler, MBC, fuel cell, wide band A/F gauge, and tuning tools. I've been looking at DSMLink. Does anyone have a option on a good link / tuner? If that isn't enough I'll start looking at ported heads with valve work and a rebuild with forged internals and higher compression. Little things will come and go so I wont list them. Like my magnetic phone holder / charger or the radar detector. My go fast goal will not change. I have been waiting a decade and actively trying to build a fast car for the last 5 years.
