Please Support STM Tuned
1G 6 bolt flex plate parts question
enriquez2000
2,277
820
Oct 5, 2014
fort collins, Colorado
Im looking for the diagram of what i need for the flexplate.. i know there are bolts(obviously) and i think a spacer or bushing of some kind... Just want to make sure I have everything i need when I start building.
Lol, I'm I'm the process myself of locating what is needed. I'm have a difficult time.
You need:
6 bolt Flex plate
Flex plate bushings(2)
Flex plate to crank bolts
Torque converter bolts
1 crank center bushing
ok i have the flex plate and the torque converter bolts, ordering the flexplate to crank bolts and JNZ has the bushings listed as spacers I believe.... i think thats where my confusion is.. i wrote spacers and someone told me bushings... I know there is a blow out diagram somewhere that shows the assembly, i just cant find it at the moment
Don't forget the flywheel spacer plate and the pilot bushing for the back of the crank!!! :)
Sorry Dstar, I was temporarily away and didn't notice that you already knew about it!
Crack me up....make me sound as old as I am...
Glad you had that on the list too. I am lucky, my son has the automatic car so I have been around them enough to know that these cars take a pilot bushing for the auto's not the stick like all other cars. You guys make sure to check out your flexplates for any cracking before you install them. The son had a crack that got worse and sounded like a rod knocking. Ended up being 2 webs that were broke. Just fyi guys!!! (wish I had an auto also).
We were sure the motor was knocking until we got the engine separated and saw what was BARELY hanging on and glad it WASN'T a rod knock. He thought about sandwiching 2 plates together and then bit the bullet and got a Kiggly plate because of the HP he was making.
Good deal, just trying to help out like you do!
Yeah, working in transmission shops over the years I've heard that sound many times and people say the same thing I think my motor is knocking. Unbolt torque converter bolts and push converter back into the pump and see if it continues or see if the flex plate is FUBAR!! Glad that's all it was vs a rod! I've have that issue and damn sure don't like it.
If i use the kiggly plate do i still need the spacers/bushings?
I am pretty sure we did use the spacers, but I know my son talked with Kiggly about all of that before we put it back together. He isn't on the forum much, but I will ask him the next time I talk to him. He DID use Kiggly flex plate bolts for the crank.
