508hp/455tq HX35 dyno
Posted by rampridersrider, Jul 18, 2010
Dyno Talk - For all the DSM dyno queens. Discuss dyno results here. For tuning discussions, use the Tuning Forum.
Please Support Race Components Inc
  1. rampridersrider
    rampridersrider Proven Member
    Dec 24, 2004
    228
    Creve Coeur, Missouri
    Decided to finally get some numbers on the GSX a couple weeks ago. I was pretty surprised actually at how easily it made over 500hp with my particular setup.
    Mods that matter.
    Eagle/Wiseco 2.0 6 bolt
    8.5:1 compression ratio
    ARP headstuds with factory Failpro headgasket
    Stock head and valvetrain with FP2 cams
    Stock 6 bolt Intake Manifold
    Stock 1g Turbo throttle body and 2g elbow
    Junk Ebay intercooler
    Crushed/Dodge modded 1g BOV
    Junk Ebay DNP knock off exhaust manifold
    7 blade HX35 with chewed up compressor wheel, w/ 12cm housing, unported and untouched
    Tial 35mm wastegate
    Full 3 inch exhaust with High flow cat
    2g maf, FP intake
    1600 cc injectors, single rewired 255 intank, stock lines and filter, E85
    DSMLink
    That should be everything that matters. First pull at 28 psi made 486 hp/420 tq, second pull at 29 psi made 497 hp/437 tq, then the final pull at 30 psi with 508 hp/455 tq. I have the car tuned for low tq, but the boost kept spiking to a few psi higher than set (spiked to 32 psi and settled to 30), so tq was a bit higher than I'd like. I think this is cause I'm on a 10 lb spring in my wastegate and the boost controller is having a hard time controlling the boost. This last pull started going rich up top so some slight tuning or possibly a boost leak test is in order. No big deal. Its still good to know that there is still plenty more left in this setup if need be, I don't think 550 is out of the question with a few more psi. No plans as of right now to increase the boost though. Enjoy.
    I included a log of the 30 psi run as well.
    YouTube - 20100709_006.mp4
    #1
  2. DSMunknown
    DSMunknown Proven Member
    Sep 16, 2004
    2,950
    27
    Worcester, Massachusetts
    Awesome numbers with your simple setup. :)
    #2
  3. rampridersrider
    Dec 24, 2004
    228
    Thanks.
    BTW, the shop informed me that all these numbers were corrected so these are the actual numbers the car made. Uncorrected would have been a bit higher.
    #3
  4. dsmdeliveryboy
    dsmdeliveryboy Proven Member
    DSM Profiles:
    Aug 14, 2007
    1,456
    4
    Medford, Oregon
    I'm very impressed!
    #4
  5. crash89
    crash89 Supporting Member
    DSM Profiles:
    Mar 5, 2008
    1,928
    71
    Janesville, Wisconsin
    Holy crap! Thats awesome! This right here gives me hope that I can put up these kind of numbers shortly in my gsx!!
    Great numbers man!
    #5
  6. knochgoon24
    knochgoon24 DSM Wiseman
    DSM Profiles:
    3
    Jan 29, 2008
    4,737
    54
    Rochester Hills, Michigan
    Boo Holsets! :p
    #6
  7. GORBS88
    GORBS88 Proven Member
    DSM Profiles:
    May 26, 2004
    527
    3
    Oliver, BC_Canada
    Great results!!
    And when do the HOLSET haters step in?
    More proof that these turbos aren't proven!:p
    #7
  8. bsbllfit7
    bsbllfit7 Proven Member
    DSM Profiles:
    Feb 17, 2009
    1,018
    Salem, Oregon
    putting one on my car here in a few weeks! Im hoping for 20-22 psi which will ###### be low 400 whp! Thats my goal atleast! Great numbers though. Go holsets!
    #8
  9. noV8undrDIShood
    noV8undrDIShood Proven Member
    DSM Profiles:
    Jan 6, 2010
    163
    Lewistown, Pennsylvania
    congrats on numbers man.. if you don;t mind me asking, were you shocked when you seen those number pop up on the first pull?
    #9
  10. absolute_DSM
    absolute_DSM Proven Member
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    Very cool. Gotta love E85.
    #10
  11. smallturbo
    smallturbo Probationary Member
    DSM Profiles:
    Feb 11, 2007
    20
    Sioux Falls, South_Dakota
    Very nice on a cheap setup! What are you running for timing?
    #11
  12. dsm-onster
    dsm-onster DSM Wiseman
    DSM Profiles:
    Jul 11, 2004
    8,218
    75
    Bloxom, Virginia
    Oh well :)
    . . . Wow this is a great result!
    #12
  13. donniekak
    donniekak DSM Wiseman
    DSM Profiles:
    Mar 23, 2008
    3,952
    402
    Surprise, Arizona
    What idc's with the 1600's?
    #13
  14. rampridersrider
    Dec 24, 2004
    228
    Yes and No. I was shocked cause I figured it was closer to 450-460 at 28 psi, but no because I was hoping the turbo was going to live up to its hype so far.
    I was on cloud 9 for about 5 minutes then my buddy did 658 in his 98 GSX right after me on a BW S364 and stock 7 bolt head/IM/valvetrain etc etc. You don't need a ton of mods to make big power, just gotta know what your doing. I bet I have less than 4k in mods into this car so far and am making over 500 whp reliably. I'll probably end up selling my 7 blade HX40 seeing as how this turbo is more than enough for now.
    I run a lot of advance down low out of boost for driveability and such, then around 7-8* when full boost hits then starts climbing again after around 6k rpm up to 19*. I have it setup to limit my torque output. You don't need a ton of torque to get these cars moving fast, all that extra torque just breaks everything.
    You can view my log in the first post.
    60%
    If I decide to up the boost I'll watch the IDC and watch to see if the afrs start leaning out to much, then I'll dial back base fuel pressure and add more global to compensate. Doing this will keep the 255 away from its crack pressure limit. But I don't think I'll have an issue till around 550-570 with fuel.
    There is a log posted in the first post for anyone wanting to view my tune.
    #14
  15. dsm-onster
    DSM Profiles:
    Jul 11, 2004
    8,218
    75
    Bloxom, Virginia
    Yes, no 'overhype'.
    #15
  16. eazy2g
    eazy2g Proven Member
    DSM Profiles:
    Jul 28, 2009
    109
    925/510, California
    Damn! E85 FTW!! Sick numbers man! I know you said stock head (maybe just internals except for cams) but did you do any porting on it?
    #16
  17. Dsmj89
    Dsmj89 Proven Member
    Nov 11, 2008
    2,150
    9
    Miami, Florida
    He mentioned it was unported in his list, read above^.
    Congrats on the results bro, great work ! Simplicity is the key. :)
    #17
  18. turboglenn
    turboglenn Proven Member
    Nov 5, 2007
    5,358
    74
    RIpley, West_Virginia
    are teh AFR's from thedyno graph accurate? If so do they match what your car's wideband is reading? Reason i ask is most people are afraid to run mid to high 12's for AFR untill they realize it knocks when rich, but i've never heard tell of some one aiming for 13.4:1 at WOT. I can't believe no one has mentioned this in this thread yet, maybe no one looked *shrugs*
    If you would please fill me in about your AFR's
    #18
  19. dsm-onster
    DSM Profiles:
    Jul 11, 2004
    8,218
    75
    Bloxom, Virginia
    Aiming for that a/f ratio is fine considering he's runing e85. . . I would think.
    #19
  20. turboglenn
    Nov 5, 2007
    5,358
    74
    interesting, it's just something i've never heard anyone talk about doing under that much boost especially, even on e85. Aside from one guys post where he had a pic of his wideband going into the 13's under boost on the dyno cause his pump ran out. Most of us that have been tuning it for a while are aiming for mid 12's, i'd like to hear more about going into the 13's with it for sure!
    #20
  21. punishment
    punishment Proven Member
    Dec 10, 2003
    173
    3
    upstate, New_York
    #21
  22. rampridersrider
    Dec 24, 2004
    228
    You're reading it wrong bud, its 12.4 not 13.4. I aim for mid 12's on E85, though another friend that day did a pull at 28 psi with a 35R where the maf was getting overrun and the afrs went into the 14's on E85 and didn't knock.
    Yah its not a bad turbo. Seems very comparible to a 3076R or a 3082.
    #22
  23. dsm-onster
    DSM Profiles:
    Jul 11, 2004
    8,218
    75
    Bloxom, Virginia
    WOW I didn't notice that. did you run that pte gasket which gives the divider a radius at least?
    #23
  24. Lavery
    Lavery Proven Member
    Sep 8, 2009
    194
    Frederick, Maryland
    This gives me motivation to get crackin on my holder build. Im impressed sir.
    #24
  25. keilum
    keilum Proven Member
    DSM Profiles:
    Jun 19, 2008
    35
    northport, Alabama
    Nice good run
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
