KaosDsm
- 0
- Sep 11, 2012
Oberlin,
Ohio
I have been building this car for a while now but never had the time to fully go at it until now. At this point in the build I am getting things all buttoned up and hopefully starting it soon after sitting for 3 years. I was new to the car scene when i purchased this car so its pretty much just been a learning process along the way. I decided to install MS3 as a full standalone instead of running the hahn portfueler. So i removed everything from the engine bay. I made 295WTQ 275WHP @18psi on the old Portfueler setup.
The build consists of:
Supertech dual valve springs and titanium retainers
+1mm oversized valves
stage 3 ported head
crower stage 3 cams
Wiseco 8:8.1 w/ ceramic coating,
coated acl bearings
eagle h beams
arp main, and rod bolts
balanced
Comp Turbo 6765
FIC 2150's
MS3
Hoosier QTP's
A set of FIC 2150's
Custom intake manifold I made. Not as nice as AMM but it will have to do!
Comp triplex 6765 triple ball bearing
I made a set of solid mounts for the front and rear mounts
Currently i am finishing up the MS3 install. I cant find anyone in the ohio area that is willing to tune on Megasquirt so i will be attempting to do that as well.
stage 3 ported head
crower stage 3 cams
coated acl bearings
eagle h beams
balanced
Comp Turbo 6765
FIC 2150's
MS3
Hoosier QTP's
A set of FIC 2150's
