Please Support ExtremePSI
420A 420a hahn portfueler wiring
Kaneis1
Sep 14, 2012
Carlisle, Pennsylvania
hi i recently bought a 420a hahn portfueler from somebody and there are no instructions or online to be found im not sure where all the wires go and also the hoses for waste gate and bov any help would be great thanks
I found some from SRTForums that might get you started:
http://www.srtforums.com/forums/f75/how-install-hahn-racecraft-portfueler-358388/
I'd match up the wire colors to your portfueler and see if they match what the srt-4 version uses (probably similar is my guess). Then research which wires you need to tap into on your car and you are well on your way!
Regarding hoses for wastegate and bov, that should be pretty self explanatory. If you are unsure about those, I'd recommend doing a lot more research on here as it is the same as other cars.
