3G brake master in a 2G
Posted by bullettdsm, Mar 9, 2013
Please Support STM Tuned
  1. bullettdsm
    bullettdsm N/T DSM Wiseman
    2,408
    29
    Joined Dec 17, 2004
    East Hampton, Connecticut
    Thought I would post this up for future searchers out there (plus let you guys know this is an option for us as well as the GS-T and GSX guys). I knew the info was out there so I did some simple searching and it took a while to get the info via search. So I figured with this title, it would be easier to find.
    This is an easy peasy upgrade. Advantages are it looks cleaner and the bore on the master cylinder is bigger (1 1/16th inch). The install? Pretty much a direct bolt-on. All you have to do is bend one line (simple enough to do by hand). Also, if you happen to have some special or painted cap, the caps are identical so you can re-use it on the 3G
    And this is what it looks like;
    MB
    Log in/Register to remove ads
  2. dsmcrzy
    dsmcrzy Proven Member
    1,092
    191
    Joined Dec 20, 2009
    Trenton, Ohio
    Thanks bullet. You beat me to it... Mine's in the mail.
    My DSM:
    1996 Mitsubishi Eclipse N/T
    Street Build
    20g   manual
    Loading...
  3. dfwdsmer
    dfwdsmer Proven Member
    39
    Joined Dec 11, 2010
    fort worth, Texas
    Nice man I just did mine yesterday
    Loading...
  4. bullettdsm
    2,408
    29
    Joined Dec 17, 2004
    Oh that reminds me. This is an upgrade over the GSX because the GSX has a 1" bore (just trying to get the info in the same thread).
    MB
  5. Goatxxmastr
    Goatxxmastr Proven Member
    48
    Joined Jan 21, 2013
    everett, Washington
    What are the benefits of the larger bore? Just curious...
  6. Black420RS
    Black420RS Proven Member
    124
    Joined Jan 29, 2009
    Tegucigalpa, HN, Central America
    did you feel better response in the pedal?
    My DSM:
    Loading...
  7. TSiAWD666
    TSiAWD666 Supporting Member
    2,065
    411
    Joined Aug 15, 2003
    Herndon, Virginia
    Best Answer
    This wasn't a direct bolt-in on my 99 gsx with abs. There was a mismatch in line fittings (inverted flare versus double flare I believe) and while the fittings on your oem lines may screw into the 3g master cylinder ports they may not be really seating properly and draw into question whether or not they will leak or let air in over time. My car's a track car and I had to be sure things sealed (I prefer not to lose my brakes on the track) so I sourced all the proper fittings and replaced the two lines with I think some -3 (or maybe it was -4?) AN lines from the master cylinder over to the abs box.
    As for which type was needed on my car... I've forgotten. You'd have to look at your lines to see which type of fitting is there and which is on the 3g master cylinder.
    Also, I think while in the OP's case both lines were able to mate with perhaps minimal bending, this may not always be the case. I'm pretty I recall on the dsmlink forums it being posted that folks without ABS had a hard line that could not be massaged into use and had to be replaced with something like a stainless steel braided line.
    Anyway, point is before you go advertising this as a drop-in on all 2g's we may want to do a bit more investigation. Sorry that I can't provide all the missing info but I tend to just work through problems and move on :-\ I'm pretty sure we had all the info worked out over at the dsmlink forums for the turbo 2g's, abs and non-abs, but I don't have the time just yet to go gather that to correct the information in this thread.
    To the question of what effect the bore has, I can't say how it would affect the stock brake calipers, but when you upgrade to a set of calipers like the Evo 8/9 that are designed to be mated to the 1 1/16" bore master cylinder you get a mushy and very deep pedal. It's actually pretty dangerous on the race track especially if you get a bit of boilover or pad knockback, as you can go so deep as to hit the end of your pedal travel and still not get the braking you need. By mating the properly matched 1 1/16" bore master cylinder to those calipers you will restore the pedal operation to what it was designed.
    I am not clear how this would be an "upgrade" to a car with stock calipers (or any calipers designed for a stock-bore master cylinder) because all it would do is shrink the braking "zone" of your pedal play. I'm not sure why you would want to do that unless perhaps you actually like the smaller zone. Now it certainly might be more to your liking as far as pedal feel, and if so by all means do it, but you're not going to brake any better with such a change.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Road Race Build
    384 whp   391 lb/ft
    Loading...
    ceedawg likes this.
  8. johnmel
    johnmel Proven Member
    176
    Joined Mar 10, 2012
    Levittown, Pennsylvania
    Just did this on mine with no problem :)
    Loading...
  9. knochgoon24
    knochgoon24 DSM Wiseman
    4,749
    61
    Joined Jan 29, 2008
    Troy, Michigan
    The fittings are different? Hmmm. I might need to check into this then. I've had a 3g BMC on my car for more than a year now.
    Loading...
  10. gofer
    gofer Moderator
    5,351
    702
    Joined Feb 18, 2006
    South Gilbert, Arizona
    Here's my info from previous posts, I guess I should have a write-up on this. Good idea Mark.
    As far as pedal feel goes, it's great. If bled properly, as I'd assume EVERYONE is doing after the install, pedal feel is the same as an Evo's. Currently I'm running rear Evo Brembos and front AWD 2 piston DSM calipers with this booster/master cylinder setup and it digs hard when I'm braking.
    When you upgrade to Evo brakes, going from AWD DSM 2 piston/1 piston to Brembo 4 piston/2 piston, the BMC must move more (pedal travel) to push enough fluid to force the caliper pistons to clamp onto the rotor. Of course the obvious fix to this is upgrading to a bigger brake master cylinder that's proportional to the caliper upgrade, in this case the 3g 1 1/16". Spongy brake pedal fixed but when one thing changes, so does another unless you compensate.
    What I'm trying to say is the brake booster essentially helps you, the driver, engage the brake pedal (using engine vacuum) to stop the car. If the brake master cylinder is over-matched (too big) for the brake booster your pedal feel will be too stiff, almost like you're braking with something stuck under the pedal. This is why it's necessary to upgrade to a bigger brake booster if you plan on upgrading to a Evo sized 1 1/16th" brake master cylinder.
    Ideal pressure at the brake caliper is 900-1200psi, according to Wilwood, so (eventually) I plan on testing this setup to see what kind of pressures I'm achieving with this upgrade. Just haven't gotten around to getting the pressure gauges to test it.
    :dsm:
    My DSM:
    1997 Mitsubishi Eclipse GST
    Street Build
    11.634 @ 126.050 MPH
    Loading...
    Teezy, Kryndon and Thermal GSX like this.
  11. bullettdsm
    2,408
    29
    Joined Dec 17, 2004
    Yup. The only reason I posted it up was because I know people who had done it so I then searched on here to find the info wasn't all that readily available.
    The titling allows for a little easier access and I'm really glad you (and others) pulled that info on here.
    As for real world applications, I personally knew of two 420a's that had this done, one GSX that had this done and one GS-T that had it done. Each one was over a year with no obvious problems. Being a member on ECMLink forums, I know that it is a private forum. Therefore everyone would not have access to this information (as well as the fact that we should have it here on tuners). So I thought it would behoove us to have a receptacle for the info that would be easily found. So thanks for that added info TSiAWD666. Very helpful to know.
    And for the bore upgrade, sometimes you think information is just as plain as the nose on your face. I guess the bore size addition I could have explained and expanded on.
    Really great additional info guys.
    MB
  12. 007jimmy
    007jimmy Proven Member
    1,391
    29
    Joined Feb 27, 2012
    I also like to add that the 3g/evo master cylinder and the brake booster is the same in some of the galant models. I got the #42 booster (pictured by gofer above) and the 1 1/16th master cylinder out of a galant. Same with johnmels car also.
    My car had ABS and the fittings were exactly the same. Besides bending the 1 line everything was bolt on.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
  13. eclipse420ags
    eclipse420ags Proven Member
    226
    Joined Feb 20, 2010
    Martinez, Georgia
    Was this on stock brakes? I dont feel like locking up the brakes every time I press the pedal. Just picked up the mbc and I guess I'll go back to the junk yard and get the brake booster.
  14. bullettdsm
    2,408
    29
    Joined Dec 17, 2004
    One was gsx brakes and one was aftermarkets (I believe Wilwoods). Both said they loved the feel of the brakes. Another good buddy in state here did an awd swap onto his Spyder and went from Wilwoods BACK to gsx. He loves it.
  15. gofer
    gofer Moderator
    5,351
    702
    Joined Feb 18, 2006
    This was the order I've done my brakes over the years...
    1. 7+8 brake booster - 15/16" GST brake master cylinder - stock FWD DSM brakes - stock lines
    2. 7+8 brake booster - 15/16" GST brake master cylinder - stock AWD DSM brakes - SS lines
    3. 7+8 brake booster - 15/16" GST brake master cylinder - Evo Brembos all around - SS lines
    4. 8+9 brake booster - 17/16" 3g brake master cylinder - Evo Brembos all around - SS lines
    5. 8+9 brake booster - 17/16" 3g brake master cylinder - stock AWD DSM front & Evo Brembo rear -SS lines
    ... and my last and final choice has been my favorite for street, mild drag (slowing from 115+mph), and pedal feel. Adding the front Evo Brembos also adds a lot of unsprung weight to the drivetrain, something I really didn't want, and switching back to the stock AWD DSM brakes I couldn't feel any difference in stopping power.
    :dsm:
    My DSM:
    Street Build
    Loading...
  16. DSM_GSX01
    DSM_GSX01 Proven Member
    793
    13
    Joined Jul 27, 2011
    La Junta, Colorado
    I would like to know is this mod better when stopping? I was going to do a EVO brembo brake swap but is it worth it?
    My DSM:
    1995 Mitsubishi Eclipse GSX
    Drag Race Build
      manual
    Loading...
  17. serviceguy
    serviceguy Supporting Member
    459
    33
    Joined May 11, 2002
    Clifton, New Jersey
    [​IMG]
    1G line at BMC on top is inverted flare M10x1.0, 3G line at BMC on the bottom is bubble flare M10x1.0.
    My DSM:
    Loading...
  18. Paul@RTM
    Paul@RTM Proven Member
    428
    24
    Joined Oct 24, 2012
    Niagara Falls, ON, Canada
    Yup, as a few guys have mentioned, stock 2g line ends are M10x1.0 inverted flare and 3g are M10x1.0 bubble flare. If you want to do it right, you'll need bubble flare at the master.
    chinola69 likes this.
  19. gsx4g64
    gsx4g64 Proven Member
    228
    3
    Joined Oct 14, 2005
    Fort Lauderdale, Florida
    I pulled a 3G Master Cylinder from my local junk yard. The one I pulled has a Rod on it. Which extends into the brake booster. I'm just guessing this is the wrong unit. Or can this rod be removed? Any help would be great. Also, what year 3g should I be looking for to get this Master Cylinder?
    My DSM:
    856 whp   587 lb/ft
    Loading...
  20. miguelmcv
    miguelmcv Proven Member
    1,983
    32
    Joined May 3, 2009
    Fresno, California
    Any 3g will work.
    The are a lot of us that have swaped to 3g bb/bm, the flare are different from our 2gs, but there are a few that we are running the stock lines with out any issue, I have heard of oly one thats had a leak on the flare location, but all the rest have had a good luck, I have this set up for a wile and never have had a problem conserning leaks,,,,,
    However, I think the best rout to go is, using the right fitting to convert the flare.
    My DSM:
    Loading...
  21. gsx4g64
    228
    3
    Joined Oct 14, 2005
    I think the M.C. I have is from a 2006 GTS. I think the only one from the 3g that can be used is from 2000-2005.
    My DSM:
    856 whp   587 lb/ft
    Loading...
  22. gofer
    gofer Moderator
    5,351
    702
    Joined Feb 18, 2006
    In the research I've done, the BB with the rod coming out of it is on the models with ABS and traction control.
    I bought my 3g BB/BMC from a part out on Club3G Forum : Mitsubishi Eclipse 3G Forums and confirmed it with the owner of the car, it was a 2003 Eclipse GT with a 5-speed, no traction control or ABS.
    :dsm:
    My DSM:
    Street Build
    Loading...
  23. kchaazz
    kchaazz Proven Member
    1,121
    66
    Joined Oct 2, 2002
    PENSACOLA, Florida
    ^^You can use the one youve got, but youve got to get the booster for it as well because of the rod that sticks out. You can get the booster off a 2001 Galant for sure as the Galant has the very same master cylinder you are describing, and the outside dimensions of its booster is the same as the #42.
    To all who are bolting the inverted flare lines to the master cylinder designed for a DPS (drill point seat), this is just plain scary. One of the things I do for a living is building brake lines of all types. When the master cylinder is dry and the lines are drained, why not just take the lines off the porportioning valve and bring em to a shop that fabricates brake tubing and have them cut off the inverted flare and put a DPS flare on the lines for you? Itll cost less than ten bucks and youll have the piece of mind knowing you dont have to worry about cracking your tubes by over- tightening the crap out of them to get the mismatched seats to seal. Not trying to start sh**e, just a little FYI.:thumb:
    My DSM:
    Loading...
    ceedawg likes this.
  24. gofer
    gofer Moderator
    5,351
    702
    Joined Feb 18, 2006
    I agree and I claim ignorance until it was brought to light a few weeks ago. Thanks for the idea, I didn't realize brake shops can cut/modify existing brake lines so I think I may call around and find one that will do it for cheap.
    :dsm:
    My DSM:
    Street Build
    Loading...
  25. eclipse420ags
    226
    Joined Feb 20, 2010
    Martinez, Georgia
    Do you have a picture of this rod?
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
