Please Support ExtremePSI
Resolved 2g TPS reversal
Bluefire16
1,500
20
Mar 30, 2007
Grand Rapids, Michigan
Question, is it possible to reverse the TPS sensor? Example, to flip it 180* degrees.
It's currently hitting my intake manifold (venom) and with the exception of adding additional spacers I'm not sure what to do.
Thanks for the help and letting me no.
Solution
You mean flip it with the connector pointing down? If so yes, mine has been that way for years works fine. Make sure you have the wings on the throttle shaft nut on the correct sides of the tabs inside the TPS and make sure it's adjusted properly when you reinstall it.
Solution
