Sbgriffin
- 185
- 16
- Jun 14, 2017
Lewiston,
Idaho
So I finally collected everything I needed to swap over to a 2g maf. Filter adapter, filter, 2g maf, and a harness adapter from ohm racing(for simplicity). Now I should state I don't have link installed yet, but it next on the list. Need to get my ECU socketed. But I didn't see any harm in installing the 2g maf in the meantime. So I did, and it took some doing with stretching my 1g intake pipe. But I finally got it with a little heat. So I go out for a quick test drive. Quickly realizing I'm running dangerously lean. I have a cheap Megan air/fuel gauge for right now, just to give me some idea. And I know they suck, because of the oscillating narrowband signal. But it's better than nothing, and definitely saved my ass that day. So I went home and changed back to my 1g maf.
Now for my questions, finally . 1st, is this to be expected without a way to tune? I've done a lot of reading about this, but haven't got a solid answer. I also know a dirty maf will cause a lean condition, because the unmetered air getting passed. I'm told it gets worse at higher rpm, which I observed in my case.
2nd, I have a good set of 550cc injectors I could throw in. I recently read on the vfaq's that with 2g maf/550's, not much tuning will be needed. The thing is, I'm not gonna go through all of that again without confirmation? Or should I just grow some patience til I get link? Sorry for the long novel, and thanks for any input.
