foxracing4500
- 336
- 9
- Jan 21, 2012
Europe
1). Any boost, vac, or exhaust leaks?
No boost leaks, shouldnt have exhaust leaks.
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
Stock Coil: yes
Wire brand and Age: ngk wires 1 year old
Spark Plug brand, type and Gap: ngk bpr6es .028 gap
5). Motor health (Compression Test)
Havent done
6). Performed basic throttle body adjustments?
Yes and no, when cold tps is on 100%. Once its hot its 1% all the time.
7). Compression ratio
2g stock
8). Any known bad sensors or brittle wiring?
No, o2 sensor is 6 months old
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.5
Injector Size (cc/min):1050cc fic low impendance
12). Properly calibrated and configured wideband sensor
Sensor Brand: AEM UEGO
Calibration Date: n/a
13). Type of fuel
Type: 93 octane
Percent of Ethanol: 10%
14). Watched ECMlink how-to videos?
Yes.
Car runs great for the most part, i am running the stock maf with a gm 3bar in place of the mdp sensor, wideband reads afr correctly but whenever i try to "smooth" my maf comp sliders i get some weird suggested templates. Any help is appreciated, my car specs are up to date. Also its an automatic.
Yes
Yes
4). Ignition system
Stock Coil: yes
Havent done
2g stock
No
Car running:
13). Type of fuel
Type: 93 octane
Yes.
