PrimerPLus
- 1,158
- 20
- Jul 28, 2011
Tokyo,
Asia
I am having issue with my clutch pedal and clutch slippage.
I don't know if my clutch is slipping because the clutch is not adjusted correctly, or
if my clutch pedal feels wrong because my clutch is going bad and slipping.
I have South Bend Clutch Heavy Duty TZ/B-Series Kevlar/Ceramic Clutch
and ACT Streetlite flywheel. This has been resurfaced maybe 2 times in the past 4 or 5 years. It has been at least a year since the last time it was resurfaced.
So Clutch pedal has about 2-3 inches of travel from the top(resting) to where it engages as your press on the clutch.
As you are coming back up it comes up hard to where you first engage it at and then it goes weak and kind of pops back all the to the rest point.
I have tried adjusting the master cylinder adjustment rod under the dash. If I go in towards the firewall it makes the clutch nice and stiff how I would like it to be all the way from top (rest) to the floor and back again BUT I can not press the slave cylinder in by hand if it is like that.
When I adjust the rod back out so that the cylinder is able to be pressed in by hand (though I am not sure it is going all the way it is very difficult to press it) the clutch pedal goes back to like it was, press on clutch from top(rest) and it will engange clutch as about 2 inches down.
I have the short Stainless Steel line that runs from the hard line to slave cylinder, newish (maybe year old or so) slave and master cylinders both OEM from JNZ.
And I also have a speed bleeder on the Slave cylinder. When I bleed the clutch I have a line running from slave cylinder nipple into a glass bottle with Brake fluid in it so no chance of any air going into the system.
So the clutch seems to slip when around 3500 rpms if I am getting on it with load and will raise up in rpms but not speed. But if I am just cruising no slippage and I have never smelt any burning of the clutch or anything like that.
Here are some pictures and a video.
a direct link to them if they don't show up in the thread here.
https://www.amazon.com/photos/share/aadttA8i4yrieI0lBZEzhBsmnZFPu73CPfIeKDiawnV
