Please Support Morrison Fabrications
Please Support ExtremePSI
2g GSX 6bolt Spark Plug firing order
Dasean Real
Apr 2, 2018
San Diego, California
Can anybody tell me how im supposed to wire my spark plug wires i have a 98 GSX with the 6 bolt swap and a black box stock 98 ECU I currently have them wired from coil 4,1,2,3 and the car wont stay on for more than like 5 seconds , i figured it was my CAS harness which i ordered another one but im not sure my wires are correct either any help would be appreciated
Not enough info here. car doesn't care what block you have. Are you running a 2gb cas, 2ga cas or 1g cas? Any of these are possible.
obviously the car doesnt care but i asssume its still relevant info im using a 1g CAS harness not sure what exact CAS it is but heres a picture
@MindBlowin03 is correct, you have the correct plug order for the 98 ECU. Any check engine codes? I would verify the 6 bolt swap wiring is correct and then check to make sure your ECU isn't fried.
im getting the P0340 P code
