awdwhip
- 356
- 0
- Jan 29, 2005
San Diego,
California
These still wont fit with 17" Rota subzero's?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Yeah but knuckles look so OEM ;-)
Do you know if the EVO X calipers can work with JDM knuckles?
I'm not sure how this would apply to these brackets since I have no data on how hot they really get but I just ran a hardness test on my friends 6061-T6 motorcycle brake rotor mount that was on his bike for about a year and we found that is was very soft. We think that the heat cycling from the brake system had removed the heat treating that the part originally had.
So it is possible to remove the heat treatment from aluminum by overheating the component but I have no idea if these brackets get anywhere near hot enough.
With that said, I would still give it a shot if I came up on some Evo brakes.
yes they do you were just looking at them.
Well if they were JDM knuckles you would not need the brackets so I don't understand what are you talking about.
Thanks for the INFO but I still don't see the JDM knuckles in the pics?Did you mil down the JDM knuckles?
Hey guys, I don't know if I should do this or not. But I found these used cts v calipers on this site for CHEAP and thought one of you guys might wanna snag them up before there gone?? CTS-V Brembo Calipers - Fully Loaded with Pads and Retainers | RallyRoad.Net $300 for everything isnt bad at all!!!
Don't worry these brackets are overkill there more beefer then most aftermaket adapter out there.The bolts thats holding them are m12 much stronger then the m10 bolts on the ears that other brackets uses. look at these made out 1\4" t6 aluminum being sold. This route is only good if got the brembo for dirt cheap like i did. like i said is not the cheapest way to get brembos aleast now we know there are more options.
