2g easy brake upgrade using cobalt ss turbo brembo monoblock calipers
Posted by sleeperX2013, Mar 19, 2014
Please Support Strictly Performance Motorsports
  1. sleeperX2013
    sleeperX2013 Proven Member
    46
    Joined May 5, 2013
    Omaha, Nebraska
    So yeah guys thought I would share this with you. Cobalt ss turbo brembo monoblock calipers 30 minute upgrade. All you need is the calipers bolts and a die grinder with a small diameter metal bit. These calipers almost bolt directly on the 2g front spindles . You need to awl out one of the factory spindle holes for the factory 2g caliper bracket about an 1/8 of an inch and then they bolt right on. You can use factory rotors like I have pictured as of right now, but you have room for evo 8 / 9 rotors which I will be doing as soon as they arrive. I figured out all of this by mistake and am very pleased with the upgrade. It literally took me 45 minutes for both sides
    Log in/Register to remove ads
  2. sirbow2
    sirbow2 Proven Member
    62
    Joined Apr 10, 2013
    Rapid City, South Dakota
    spose we cant post in the tech article forum yet :( this would be great for there. you wouldn't happen to have any pics of it, would you?
  3. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
  4. gieri002
    gieri002 Proven Member
    729
    Joined Feb 25, 2008
    Lake Minnetonka, Minnesota
    Wow, great find. This changes the game.
  5. evileagleawd
    evileagleawd Proven Member
    155
    Joined Nov 10, 2008
    Vineland, New Jersey
    I checked out your pics and you mounted your calipers up side down. The bleeder needs to point up.
    Loading...
  6. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
    Evileagleawd thank you for your advice. I didn't know that I just figured to point them downward to keep from getting fluid on the finish. But now thinking mechanically that makes perfect sense because all the air would sit at the top......duh! Lol thanks
  7. okm12346
    okm12346 Proven Member
    498
    12
    Joined Dec 3, 2007
    Chicago, Illinois
    Good find. Keep us updated on the evo 8 rotor fitting.
  8. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
    I definitely will. Does anyone know the diameter of the evo rotors and 2g rotors? Because I have another 5/8 of an inch clearance between the calipers and rotors which will allow me another inch diameter of rotor
  9. okm12346
    498
    12
    Joined Dec 3, 2007
    Chicago, Illinois
    Stock 2g GSX'99 is equipped with:
    FRONT:
    - vented rotors diam275mm (10.8") = MR389727/MR449818
    - 2-piston calipers (Sigma) = MB950176 & MB950177
    REAR:
    - regular rotors = MB928716
    - 1-piston calipers = MR129583 & MR129584
    EVO-5,6,7,8,9 (possibly 10?) is equipped with:
    FRONT:
    - vented rotors 320x32mm (12.59"x1.25")
    - 4-piston calipers
    REAR:
    - vented rotors 300x20mm (11.8"x0.78")
    - 2-piston calipers
    [​IMG]
  10. InTheDeTaiLs
    InTheDeTaiLs Probationary Member
    Joined Mar 19, 2014
    Duluth, Minnesota
    What is the distance from bolt hole to bolt hole on the Colt caliper?
  11. gieri002
    729
    Joined Feb 25, 2008
    Front Evo 8 rotor diameter: 320mm
    Front 2g awd rotor diameter: 276mm
    Edit: Nice, you beat me to it.
    It looks like the rotors on the 08+ cobalt SS with brembos have a diameter of 315mm (12.4")
  12. cait sith
    cait sith Proven Member
    1,311
    10
    Joined Nov 22, 2002
    Brooklyn, New York
    What a neat little surprise. It doesn't shock me that some other car uses the same brake caliper mounting hole dimensions, but it's nice to know that you can throw these on with no sweat. You could probably fit EVO rotors without a problem.
    My DSM:
    1998 Eagle Talon TSi AWD (sold)
    Road Race Build
    386 whp   340 lb/ft
    1997 Mitsubishi Eclipse GSX (sold)
    T28   manual
    Loading...
  13. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
    Hmm? Idk if I'm going to be able to fit the evo rotors on there but I do have a guy that could machine down the diameter of the rotor to make it fit . I'll keep you posted on the outcome
  14. synthetek
    synthetek DSM Wiseman
    1,534
    75
    Joined Dec 13, 2005
    La palma, California
    If the EVO rotors are too big the outlander rotors might work they are 296mm
    My DSM:
    1999 Mitsubishi Eclipse GSX
    13.629 @ 99.970 MPH
    1995 Mitsubishi Eclipse GSX
    Street Build
    T28   manual
    Loading...
  15. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
    Did some research and the cobalt rotors are 290mm (11.6") so it looks like I could use those as long as they're not too different from the dsm hub. I'll try a set from the parts store and see what happens.
  16. miliman13
    miliman13 Proven Member
    1,521
    260
    Joined Jan 1, 2011
    tampa, Florida
    1st off, awesome find, what do you mean by accident ?
    and what does " awl " mean ? im not familiar with the term.
    did the stock 2g lines fit with no issue?-thanks.
    My DSM:
    Loading...
  17. InTheDeTaiLs
    Joined Mar 19, 2014
    Duluth, Minnesota
  18. Yamahaulin
    Yamahaulin Proven Member
    645
    13
    Joined Jan 30, 2010
    Bowling Green, Kentucky
    Evo 8/9 is 12.8 and I believe 2g is 10.6
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
  19. gieri002
    729
    Joined Feb 25, 2008
    That's not what I found...
    2009 Cobalt SS rotor size? - Cobalt SS Network
  20. sleeperX2013
    46
    Joined May 5, 2013
    Omaha, Nebraska
    Miliman13 what I meant by accident was my buddy had these calipers laying around his garage, and I borrowed them to see if I could make a bracket to use these on my 2g. When I took my oem caliper and bracket off I lined the two mounting surfaces up and noticed that the brembos were only off by an 1/8 inch or so . So I started mocking them up and came to the conclusion that all I had to do was awl/ notch one of the holes on the spindle and they were a direct bolt on. And to answer your other question the factory line works perfectly using the brembo banjo bolt and crush washers. :thumb:
  21. dot45
    dot45 Supporting VIP
    128
    Joined Sep 26, 2011
    Oak Park, Michigan
    Just to be clear, you elongated one of the holes in the spindle?
    I already have the j-spec knuckles for my evo brakes (if the weather ever warms up.....)
    I don't think I would feel at ease, knowing that one of the fasteners holding my caliper to the car is riding in a slot.
    My DSM:
    Loading...
  22. miliman13
    1,521
    260
    Joined Jan 1, 2011
    tampa, Florida
    LOL:thumb::thumb:LOL
    so these would be the same? $_3.JPG any idea if the years differ ?
    My DSM:
    Loading...
  23. GPLaserRS
    GPLaserRS Proven Member
    223
    22
    Joined Aug 23, 2005
    Grosse Pointe, Michigan
    The rotor the Cobalt uses is 12.4" in diameter, the problem you'll run into is that to use the cobalt rotor the hub is 5x110. We run 5x114.3. I did find the calipers on RockAuto for $105/caliper including the core charge. You're gonna need to measure what size rotor you need to run because the spacing from the hub center compared between the Cobalt and a DSM is going to be different. But this is definitely an awesome find!
    My DSM:
    1992 Plymouth Laser RS Turbo AWD
    Street Build
    16g   manual
    Loading...
  24. miliman13
    1,521
    260
    Joined Jan 1, 2011
    tampa, Florida
    ya, lets find out. These are a way cheaper alternative; concluding from a quick ebay search
    My DSM:
    Loading...
  25. okm12346
    498
    12
    Joined Dec 3, 2007
    Chicago, Illinois
    the 94+ 3000gt vr4 rotors are 314mm
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
