Moparbishi
- 112
- 0
- Sep 15, 2007
Fremont,
Nebraska
Hi folks, last fall I was rear ended by an uninsured driver in my 98 all wheel talon. It received body damage in the rear and I now need a donor car. I have a lead on a rust free gsx, but it is two hours away. I know the gsx would be the correct metal to cut from and use as a donor.
If I could find a gs that was local I would go that route as long as the body is the same. So basically that is the question, can I use a gs donor car?, or would it be best to start with an all wheel donor? I work in a body shop and will have the help of a 65year old tech before he retires. For some reason I though two wheel drive trunk pans are different than all wheel, if im not mistaken. That's what got crushed the most is the trunk pan. Any help would be appreciated, thanks.
