GSXbooster
Supporting Member
- 177
- 134
- Jun 3, 2003
Centennial,
Colorado
Nooice! Got my tracking info.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks again bobby.
Wife said mine showed up today. Can't wait to get off work so I can take a look at them.
What are you planning on next?
-seat brackets for side mounts?
-toe hooks?
- replacement for discontinued RM sway bar?
-front UCA?
-bar or something to move the radiator away from the exhaust manifold so we can run another fan, etc?
-spare wheel wheel cover like yours as I think frontline. Stopped making theres?
Hello again Tuners, List closed!!!! 9/6/17
Welcome to my next item I have designed and developed in the quest for better suspension setup and handling for the 2G!
If you have lowered your car and/or want to add alot of caster then these are for you! they also remove any slack a ball joint may have and give ultimate driver feedback to the steering wheel for a more precise feel. Caster makes the connection area drop resulting in out of sync and and a massive issue for toe change in steering and cornering/braking! If you serious about handling then this is something you need.
These feature the same high end race Chromoly rod ends I always use and will continue to use for strength and quality.
ABOUT THE ITEM
Adjuster shafts a made from EN24T for amazing strength and have the same length internally as an OEM outer tie rod end so no loss of length or threads, spacers are also now EN24T to match and have offset heights for adjustment and washers are included aswel if needed, everything will be clear ZINC plated and will include rubber dust covers for the rod ends aswel, taper spacer inserts into the knuckle so no need to drill or reem the knuckle out! its what you would call plug and play to an extent.
Hardware will be a 12.9 socket capped bolt and flanged nyloc nut to secure into place.
For installation most of the time these will be placed above the knuckle like oem ones are, for those that are really low then you may try to use below the knuckle!
SETUP is critical to getting correct, the use of a bump steer gauge is best to get super accurate results, a link here walks you through best ways to setup and troubleshoot http://www.longacreracing.com/technical-articles.aspx?item=8162
When i tested my car out, oem tie rods vs my new kit i managed to dial alot if not most of it out all from the fact of lowering my car!
Lowering the car 2" sees a toe of 50 thou (1.27mm) uppon compression! this is alot!
Oem tie rods and lowered 1 1/4" produced 32 thou! (0.8128mm) uppon compression! Thats also a fair amount
My kit same ride height of 1 1/4" managed to get it to just 9 thou!!! (0.2286mm) thats much better and its also better then stock is at oem heights!
PLEASE READ DETAILS
Price is going to be an entry price for this batch of $250 shipped via FedEx, fully tracked and insured, after this first batch they will go up to $275 for all other batches, This is a very cheap kit compared to everything else on the market for a bump steer kit and its built by a DSMER for DSMERS!!!
list will close on the 10th JUNE 2017 minimum of 20 to enable me to go ahead and to continue to make them in the future, If these dont go ahead then i most likely wont produce them ever.
If you have any questions please as always feel free to PM me or comment in here and I will reply as I always do,
When sending paypal please include phone number as its so much easier for me to get all your details from 1 place,
1. GSXbooster (SHIPPED)
2. llxKevinxll (SHIPPED)
3. SlowWhite (SHIPPED)
4. Gsxitement (SHIPPED)
5. Zmann42087 (SHIPPED)
6. Greengoblin (SHIPPED)
7. Apache (SHIPPED)
8. Dskagr (SHIPPED)
9. TheLemon (SHIPPED)
10. Viciouslord (SHIPPED)
11. 99redgst (SHIPPED)
12. Apache* (SHIPPED)
13. Mantega4g63 (SHIPPED)
14. Chinola69 (SHIPPED)
15. tunedbysaturnsl (SHIPPED)
16. 95eclipser (SHIPPED)
17. 1point8LTpower (SHIPPED)
18. T2Small (SHIPPED)
19. Coloradotuner (SHIPPED)
20. Eclipse 1998 (SHIPPED)
ALL SHIPPED!!!!!
Thank youYou must be logged in to view this image or video.You must be logged in to view this image or video.You must be logged in to view this image or video.You must be logged in to view this image or video.You must be logged in to view this image or video.
How do we setup the purchase. I need the kit bad.Hello again Tuners, List closed!!!! 9/6/17
ABOUT THE ITEM
PLEASE READ DETAILS
7. Apache (SHIPPED)
8. Dskagr (SHIPPED)
ALL SHIPPED!!!!!
I dont have any as the list was closed and i make what was paid for, i am considering making another batch though as i have had several folks ask me, i shall put you on my list of people to contact when i get to make another batch up,How do we setup the purchase. I need the kit bad.
