1slowhatch
- 172
- 2
- Mar 5, 2014
Reno,
Nevada
What kind of lb/min are you guys getting on OEM B16g turbos? Mine has been ported on the turbine side, wastegate, o2 housing, manifold ( opened 7 cm gasket, and slight port match @ head). I have stock exhaust except removing the rear most muffler. The intake side is a VRSF intercooler kit, fenderwell intake 3" w/filter.
I have seen a peak of 27.5lb/min on a cool night at 19 psi. Is this right..?? Low???
It seems like the FMIC install did get me a little bit more airflow.. before on 22 psi on a cool night I'd see maybe 26.5-27lb min MAX.
Also, how much power should this be good for? I've heard 1 lb/min is roughly 10 crank HP?
