bastarddsm
- 5,643
- 1,478
- Aug 26, 2003
Mendota,
Illinois
I'd be tempted to make a push lock 2bolt flang to bolt on the pan like stock
Note: This feature currently requires accessing the site using the built-in Safari browser.
How are you anticipating the wastegate flapper is going to open with the actuator pushing the opposite direction like that?
For what you're attempting to work, you'd need to re-mount the actuator lever to the bottom side of the housing....180* off of how it is on a stock HY35, as on a stock HY the actuator pushes toward the exhaust housing to open the wastegate; yours is pushing toward the compressor housing.
That's what I was thinking .How are you anticipating the wastegate flapper is going to open with the actuator pushing the opposite direction like that?
Ah! I see it now. It's the little things . Let us know how it works out. I'm curious as to how well it will control boost.He flipped the flapper pegs orientation, its correct now. Zoom in on the third pic and youll see the re-welded flapper arm.
Wrong- it would make ALL the boost that way.You wouldn't make any boost that way
Yessir.Fixed?
That was before he fixed it. Wouldn't it not make boost (Maybe a few psi) due to the flapper being pulled open instead of being held closed? If he could make all the boost than why did he need to fix it. Like when the wastegate arm falls off you make no boost.
Did the turbo compressor touch the waterpipe? This is the tube that connects to your water pump right. Did u have to dent it?
