stiggity99
- 231
- 4
- Mar 31, 2011
York Haven,
Pennsylvania
As soon as I adjust my MBC to anything greater than 19lbs of boost, ill get into it in 2nd gear, and right as the engine reaches >3800RPMS, you can hear the power STOP and a fluttering through the exhaust. If I try to stay into it, it bucks, and I get out of it. I can ride 19psi till 7000RPM and it runs perfect. As soon as the boost pressure is changed to 20/22/23/25, Whatever, in 2nd gear especially it loses all power, flutters, and that's where im stuck at. Fuel pressure is set to 43.5 via Fuel Lab regulator, -6an from filter to rail. Is there a difference between 1g and 2g fuel filters? Let's say (im pretty sure not), im running a 1g fuel filter.. could this cause the problem? Anny help would be greatly appreciated.
--Steve
--Steve
