Are you gonna be surprising us with adjustable upper control arms? OK, I will wait patiently for the next set Log in/Register to remove ads
Do you have clearer pictures of the clevis rod completely unthreaded from the control arm? I want to see how much thread there is to play with.
Depends on car specific setup, im lowered to about 1.5", ride height is currently 4.75" F / 5.25" R, And i worked out my specific setup and my roll centers so i opted for the middle hole to not only keep my arms at a nicer level but it ment in motion and in cornering it did not offer alot of bump camber which related to more tread on the road overall! Since everyone is different its hard to say for every car and its specific setup, some might still use the bottom hole some may want to use the upper most hole , every guy that sets up or has it setup is different from the next. The general idea is to bring the arms motion in spec again but then the flip side is to also mess with the motion to suit the driver/car if that makes sense!
Start with the lowest hole and go from there, the lowest hole is the (oem) stock location hole so unless you know already otherwise start there and then adjust to suit you and your car, i oreworked out my setup not only from just driving it and knowing but i did motion mockups on paper of how it will benifit me specifically if i went to the next hole and it counteracted the lowering process and how the lower arms sat after lowering,
The more people who buy now will help him create more goodies for us in 2017!!! More then happy to support this freelancer.
I'm in too. Double checking, this would work with my 2GB Spyder with future AWD swap right? How do I make payment?
It will work with all 2G suspension setups, its specific for all models released in the 2G platform but does also work with the 3G eclipse and Galant aswell that uses the wishbine system
Couple more weeks left guys, if your lowered and want better suspension setup and to help with optimum handling and adjustments then these are going to aid everyone!!! Designed for motorsports and used on the roads. These are a great item to have in your suspension system
right folks, this closes next sat the 14TH!!!!! can I ask if you want in please get in touch and the rest of you with deposits please can we sort the remaining balance please guys, im starting to order parts in from monday the 9TH! this monday thanks everyone
Thanks, I'm redoing the whole suspension system to make it modern and to include as much adjustable parts as possible! It's about time we got more modern suspension
Already drawing the rear subframe out haha, it's one of my last things to look into though, front will be after that of course,
