2G Adjustable tubular Rear upper arm/wishbones, With roll center adjustment.
Posted by ec17pse, Dec 1, 2016
Please Support ExtremePSI
  1. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Im here to also listen to you all and give you what you ALL want as well as I have to make you all happy and love my stuff too haha,
    I have just got home and sat down and worked it out and I can do 2 holes to the outer bracket but this means
    ** by design It will automatically come with NEG 1* of camber built into the arms this can be removed by unthreading the rod ends more and get it back to oem arm length so you will not loose any adjustment range at all!!!**
    on my other workings out I believe I can have more camber by adding it on the rod end and that would mean it could get close to -2.7* of camber and still retain the +1.5* of camber
    so as to my pro paint shop drawing below LOL the 2 white dots are the holes being used! and the central is not cut at all! this keeps them all in the same location as before in my design!
    if this is ok with everyone I can adjust the laser cutting to go this route if it will help relieve you all of any strength issues! let me know and I will get them to adjust the drawing tomorrow
    Log in/Register to remove ads
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  2. Black95TSIawd
    Black95TSIawd Proven Member
    1,603
    240
    Joined Jan 28, 2003
    Dirty, New Jersey
    Just to confirm, we will be able to adjust camber from 2 points. One, where the knuckle mounts to the upper arm.(Where your holes are drilled.) And two, at the rod ends?
    I've been thinking about this more and more, please don't mind. But, when we lower our cars, the rears camber in pretty good and we have to add camber to get into "spec". Even at -2.4 degrees, I still added washers. Does changing the arm height (roll center) affect the camber curve? Will so much negative adjustment even be necessary?
    My DSM:
    1998 Eagle Talon TSi AWD
    184.4 whp   251.0 lb/ft
    1997 Mitsubishi Eclipse GSX (sold)
    Drag Race Build
    20g   manual
    Loading...
  3. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    thats correct the most inner hole on the outer bracket will be the hole that will give -1* camber from design the one towards the outside of the car will give you pos camber incase you need to loose some neg camber, then the rod ends for fine tuning, the higher you go on the roll center inner bracket will take away camber but you can add that back in the adjustments from the rod ends, the camber curve is altered of course depending on your setup, mine has been set to not gain less camber on compression and keep a flatter tire in a turn to retain tire grip and not loose the grip via more camber.
    I dont have to add the extra camber in the arms and I can put that back into giving more + camber as it was originally designed for, I know it can become too much and It was just an idea to add more camber being neg rather then pos camber. I wont add the extra camber then but just remove this 1 hole and that will solve all the worries and still have a wide range of adjustments.
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  4. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    once we are all ok with it and I can keep you all happy people I will adjust the sale post to reflect the new bracket that will be used to make it much clearer for the buyers to see whats actually happening.
    Thanks for your input folks. Im just trying to get this arranged for you all how YOU all feel comfortable with them plus without adding costs to having more parts laser cut or items needed. cost is what im trying to keep fairly low for you all while giving you quality product(s)
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  5. ileagleracing
    ileagleracing Supporting Member
    180
    67
    Joined Sep 27, 2007
    Montreal, QC, Canada
    Can you provide the dimensions below? I was looking at some changes to my billet knuckle design to maximize tire clearance and I want to see how your arm design impacts that. upperRCA.jpg
    My DSM:
    Autocross Build
    313 whp   305 lb/ft
    1995 Eagle Talon TSi AWD
    Autocross Build
    160 whp   190 lb/ft
    Loading...
  6. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    back to the top folks, any more for arms?
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  7. llxkevinxll
    llxkevinxll Proven Member
    53
    15
    Joined Jan 29, 2012
    Cleveland, Ohio
    I am throwing in my vote for retaining the center hole on the outer joint. I would prefer to have a wider range of adjustment as well as retaining oem spec should I need it at some point in the future.
    My DSM:
    1996 Eagle Talon TSi AWD
    Autocross Build
    14.4 @ 100 MPH
    1992 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
  8. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Haha, I may need to put a full vote out to all and see what everyone wants!
    you can still get to the oem range by unthreading the rod end more, I have been through my initial designs recently and it can be done safely aswell. basically with removing the central hole in the outer bracket the rod ends play more of a role to getting the correct range needed,
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  9. llxkevinxll
    53
    15
    Joined Jan 29, 2012
    Cleveland, Ohio
    OK that sounds fine to me. Thanks for clearing that up.
    My DSM:
    Autocross Build
    14.4 @ 100 MPH
    Street Build
    16g   manual
    Loading...
  10. 95eclipser
    95eclipser Proven Member
    666
    217
    Joined Feb 3, 2006
    Manassas, Virginia
    possibly in. Sent you a PM
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Street Build
    464 whp   379 lb/ft
    10.920 @ 133.900 MPH
    Loading...
  11. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Replied
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  12. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Yeah no problems. a few were worried about that central hole strength even though mines been fine for months its still what everyone wants at the end of the day, I want to cater for all and make sure everyone is happy without having 2 types of everything as that gets confusing and things go wrong fast haha. I know its not your normal typical design LOL.
    At least it can be reverted back to oem lengths plus more pos camber with the most outer hole so the arms wrok in the same way with the same ranges just minus 1 central hole.
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  13. 95eclipser
    666
    217
    Joined Feb 3, 2006
    Manassas, Virginia
    I'm in as well deposit sent.
    Thanks!
    My DSM:
    Street Build
    464 whp   379 lb/ft
    Loading...
  14. TSiAWD666
    TSiAWD666 Supporting Member
    1,994
    289
    Joined Aug 15, 2003
    Herndon, Virginia
    At near or around stock ride height what is the camber range of adjustment?
    My DSM:
    Road Race Build
    376 whp   344 lb/ft
    Loading...
  15. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Stock ride height is adjustable to -2.2 / +1.5 i mocked these up from my stock spare chassis i have so its as close to stock as im going to get.
    im now thinking since i re worked out the adjustment again on the rod end side of things that i can gain possibly another half degree each way so from my new estimate if my drawings and calculations are correct it may be able to go -2.7 and / +2.0 as a guestimate.
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  16. TSiAWD666
    1,994
    289
    Joined Aug 15, 2003
    Herndon, Virginia
    Count me in then, range is good for me, just leave out that center hole.
    My DSM:
    Road Race Build
    376 whp   344 lb/ft
    Loading...
  17. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Center hole is being taken now but can still be adjusted for its removal. Laser cutters ready been updated!
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  18. 95eclipser
    666
    217
    Joined Feb 3, 2006
    Manassas, Virginia
    Glad to see the list is filling up fast!
    My DSM:
    Street Build
    464 whp   379 lb/ft
    Loading...
  19. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    It sure is, hope I can jump to the other side of 10 but we shall see what happens!
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  20. T2Small
    T2Small Proven Member
    114
    12
    Joined Dec 22, 2003
    Victoria,
    If the centre hole is left out, I'm in.
    My DSM:
    1997 Eagle Talon TSi
    Autocross Build
    433 whp   352 lb/ft
    Loading...
  21. 95eclipser
    666
    217
    Joined Feb 3, 2006
    Manassas, Virginia
    I'm pretty sure the center hole is being removed. Check first post!
    Now pay the guy and get your name on this list!
    My DSM:
    Street Build
    464 whp   379 lb/ft
    Loading...
  22. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Shoot me a pm then i can get you added, Thanks
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  23. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    Well that's 10 on the list! Wonder if I can get to the other side 10?
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  24. barza21
    barza21 Proven Member
    61
    8
    Joined Oct 11, 2006
    Fairbanks, Alaska
    If you get a group buy going sometime in the middle of the first quarter of 2017, I'll be able to afford them. I would definitely pick up a pair then
  25. ec17pse
    ec17pse Freelancer
    2,499
    610
    Joined Nov 1, 2008
    London, Europe
    It won't be likely I'm afraid, if I did another batch of these it won't be till at least summertime as I've got other items I'm planning to bring out in the new year
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
