Please Support STM Tuned
Please Support Rix Racing
2G 1st custom job w/ pics
jbeaton9292
847
72
Aug 29, 2013
Sterling heights, Michigan
Ok so i decided to try and make my own vent gauge pod for my wideband and boost gauge i used the vfaq to see how its been done gave me a idea of how to go about it
So what i did is took my old 1g a pillar dual pod and cut the gauge holders off angled them by running the on side of fiber cutoff wheel the glued them where i wanted them to vent bezel (hot glue) then i pull nylon leggings over it and glued it down where i needed to hold it all in place (after streched tight) then i used the fiberglass resin kit from walmart 17$ comes with resin hardener spreader stir stick fiberglass cloth (stuff stinks sobad LOL) and just slapped on a quick layer on the nylon so it will harden and add more so it cantleak through the nylon thats as far as ive made it so far pics attached
Second coat of resin 1st layer looked so shitty this layer looks pretty decent i would say im only using a popsicle stick that came in the kit LOL
[DOUBLEPOST=1407941622][/DOUBLEPOST]3rd coat coming along well how many coats should i use im making it thick
Almost done sanding and 3 heavy coats was plenty
[DOUBLEPOST=1407951516][/DOUBLEPOST]Finished looks pretty good
[DOUBLEPOST=1407952952][/DOUBLEPOST]Painted not gonna lie i was kinda scared to try this but im glad i did it was super easy
Not bad for your first time! I have a spare vent that I was thinking about doing that with. I just finished one for the drivers door vent but not sure if I am going to use it.
Right now I have a 3 pod vent I made under the radio.
Yea that's the only down side to this mounting solution.
I do mount my tablet to the vent gauges and use that over Bluetooth to display info off my Megasquirt. So the majority of my data is displayed there.
