Joshky9
- 87
- 0
- Sep 18, 2005
Canal Fulton,
Ohio
After dropping the motor back into my brother's car the one listed in my profile the headlights will go up automatically but will not go down. They will go down with ease when doing so manually. I even re lubricated all the hinges just in case. I have searched multiple threads already and I have already checked these items. What is nice is I have just purchased a 91 eagle talon TSI with working headlight motors So I have been able to check all of these items.
1. The Driver side Headlight motor switch is not the culprit. Switched all three on that side without change in symptoms. The switch is also not depressed or on we have tried a multitude of different combination even trying to depress the fog light etc.
2. Checked the fuses in car and in the engine bay.
3. Checked and swapped all the relays in the engine bay involving the headlight assembly/motor
4. When Probing the wiring harness on the car while pressing the headlight motor switch we get 12 volts on the LY or up terminal according to this wiring diagram.
http://www.dsmtuners.com/forums/attachment.php?attachmentid=142344&d=1342753970
-What is interesting is when I probe this same connection on my car the 91 talon which the headlight assembly's work this pin will show 12 volts then will go back down to 0 as compared to the non working car which it will just show 12 volts and it will stay 12 volts until we depress the switch again. The LR on the non working car therefore do not show 12 volt when we try to press the headlight motor switch again.
I apologize for this being so long but I have been frustrated with this so far. Any help would be greatly appreciated.
