Please Support STM Tuned
Please Support ExtremePSI
General 1g wideband ecu pin
brynden29
127
May 15, 2002
Round Rock, Texas
Hey guys,
I did a lot of searching and everything I found pertained to 2gs.
I just installed my MTX-L o2. Everything went fine, I wired the yellow wire to the ecu, (pin 4 - white wire) enabled the narrowband sim, selected the input for LC-1 Wideband, changed the W/B drop down to front o2, and did the open air calibration. When I fire it up, the gauge seems to work but the ecu reading for the o2 is stuck at .80 and the LC1WB value is stuck at 7.4:1.
I am not sure that I tapped the correct pin. Can you look at the attached pic and let me know what you think?
Thanks so much.
Here is the pin-out for 91-94 1g:
You appear to have wired the sensor to pin 9. You needed pin 4. White wire with a red stripe. I would recommend soldering the connections and using shrink tube as opposed to using butt splices.
