Please Support Rix Racing
1G Weird noise coming from gold box under shifter?
chanley talon
774
14
Nov 10, 2005
Spencer, Indiana
Hello,
My car starting making this noise after i shut the key off. I smelt a strange almost wire burning smell but found no bad wires. My car still runs and drives? What is it . What should i do or check out.
Please see video!
It looks like it might be the MPI Control Relay circled in the picture I attached, although it's hard to tell exactly when comparing your video to my service manual. The easiest way to tell would be to check for a part number (I can't quite make it out in the video) to enter into Google.
Thanks for helping . I found the issue. Watch the video. Can someone fix this ecu?
  • IC105 controls ECU pins 67 and 68, Idle Speed Control (ISC) Servo (coil pair B).
    Im not sure why it caused the buzzing of the MPI Relay but it is for sure what the issue was.
