Please Support Kiggly Racing
Please Support STM Tuned
1g rear subframe bolts
chacedog1
56
Oct 20, 2011
southeast, Massachusetts
hi all im looking for the bolts that hold up the rear subframe in my 91 gsx. they are 6 bolts total (3 on each side) that hold up the triangle stud (2 total triangle studs 1 on each side) to mount up the front part of the rear sub frame. not sure if there are a mitsu part # for them or if anyone knows the bolt size that I could go to home depot or autozone. thanks in advance
Here is a pic
its weird, for 89-92, it says 12x25 length (MF241307), for 92-93, it says 12x30mm length (colored) (MS240118). pretty sure they're m12x1.25 thread pitch.
no idea what the whole (colored) thing is
thanks again tmoney cant tell you how much you have helped me through this project
its 80-94 ft-lbs for the nut that goes on the big center shaft thingy, looking for the 3 bolts-to-body...
51-61 ft-lbs for the bolt that holds up the kidney plate you have to take off as well, forward of the rear-subframe, i'll bet the 3 body bolts are similar, still looking...
I can't find that one, but the 51-61 ft-lbs is "Crossmember bracket to body", so I'm sure 51-61 for that, which I'm sure is the same bolt as the 3 bolts on that thing, would suffice.
