LaserRS92
Supporting VIP
- 284
- 16
- Aug 14, 2008
Fort Wayne,
Indiana
Hi there, I have a 93 Eagle Talon Auto AWD. I just swapped in my 6 bolt out of my 92 Laser I had. I am getting error codes 14: throttle position sensor and 25: barometric pressure sensor codes. I cannot for the life of me get these to go away.
Some history, I'm using the same sensors from the 6 bolt and a 94 style manual ecu since my 6 bolt has a 14b and 450s. I tried a known good condition maf and the tps off the 7 bolt that came off the car to no avail. Trying to give it gas with these parts caused like a 2k rpm two step in park and a 1200rpm two step when driving. It would buck and go nuts trying to give it gas.
Leaving the ecu pins the same, I put in a 90 ecu. I can accelerate but of course have permanent codes from not the right year ecu. Still the same codes. Changing pins 6 and 14 like a normal ecu swap, the issues still persist but I can accelerate.
So, I think I was having some issues with my 94 ecu since I couldn't even accelerate or give it gas. However, I was tentative at first for the pin out swap because this auto harness isn't the same colors as a manual one. I don't know what else to try. Maybe the tcu? It wasn't wanting to grab 2nd gear. I know that looks at tps inputs.
I need help!!
Do you guys think it's worth sending in my ecu and tcu to Tom and see if he finds anything? Things did get better when the 90 style ecu was in there.
I need help!!
