primo513
- 117
- 1
- Jun 1, 2011
Cincinnati,
Ohio
For sale: 1997 eagle talon tsi awd (90,050 miles)
Asking: $8000
I will continue to add stuff as I think about it.
Bought from a friend last year, selling to buy a house. Car is garage kept. I am including all information that I know about. Previous owner ran a 9.2 @151 on a 2.3 with larger turbo
Motor:
-built 2.0 4g63 ~2000 miles (I only put on about 100)
-Manley crank
-Eagle rods
-Weisco pistons
-Kiggly beehives
-kiggly HLA pressure regulator
-Bc 272s
-Ported/polished head
-VC is with fabricator to get catch can fittings #10 (its also fresh powder coated black but does not have a catch can included)
Trans:
-stock auto rebuild with kiggly end clutches and precision converter
Turbo setup:
-Precision 6262 (~100 miles on it and I've only gone up to 27psi at peak a couple times so far)
-Dnp t3 mani
-Turbonetics wg
-4" custom ETS fmic core with 2.5" piping
-Tial 50mm bov
-Smim (unknown brand)
Fuel:
-Custom stock location aluminum fuel cell (8-9 gals)
-Magnafuel protuner 750 pump
-Fic 2150s (~100 miles and no e85)
-Aem fuel rail
-Fuel labs afpr
-Fuel labs filters (prepump and preinjector)
Chassis:
-8 point cage with racequip harnesses
-Tubular front end
-Comes with 2 aluminum kirkys (and seat covers) and brackets to install them, but the fab work isn't done
-Carbon fiber hood (not the best shape but does its job)
-koni suspension
Misc:
-Ecmlink v3 tuned with speed density (aem 5 bar map & gm iat)
-Dynatek arc2 ignition
-Forced four manual shift box
-Large trans cooler
-Mishimoto rad
-3" aluminum exhaust with flex fittings to finish the exhaust system (right now it dumps to the ground)
-Rota slip stream with hoosier slicks (also comes with second set of wheels with brand new winter tires)
-audi vacuum pump to assist brake booster (plumbed but not wired for power)
-electronic boost controller from ecmlink (not plumbed or wired for power)
-oil cooler and lines
-rear diff polys (not installed)
There is a ton I am missing, obviously looking at the list of mods and the previous owner's track time you can tell this was a race car, and still can be! I just never had the time to enjoy it due to have two surgeries after I bought the car and now I'm buying a house. Ask any questions, again I'm going to post pictures after taking some. My name is Chris. 513-2FIVE8-8543
Asking: $8000
Motor:
-Manley crank
-Eagle rods
-Weisco pistons
-Kiggly beehives
-Bc 272s
Trans:
Turbo setup:
-Dnp t3 mani
-Turbonetics wg
-Tial 50mm bov
Fuel:
-Aem fuel rail
-Fuel labs afpr
Chassis:
-Tubular front end
-koni suspension
Misc:
-Large trans cooler
-Mishimoto rad
