ryguy86eklipse
- 73
- 1
- Oct 23, 2006
Phoenix,
Arizona
Clear and clean title. No accidents.
98,000 original miles. Rebuilt engine and trans with upgrades.
Straight body with no dents or rust.
A 6-Bolt motor swap has been done!!
Car is located in Mesa, AZ..
Now to the goods.. This eclipse comes with:
+ 97 Turbo ECU that's chipped with DSMLink V3 Full and configured for Speed Density
+ Shep Racing Race Transmission w/ cooler,
+ Built 2G Head (Ferrea Valves, Web springs, Venom Cam Gears, HKS 272/272 cams) on a
+ Built 6-bolt 4G63T block (2G JE Pistons/Rings, Eagle H Beam Rods,) bottom-end
+ BBK-1750 Throttle Body
+ Venom Intake Manifold
+ FIC 950cc injectors
+ Walbro 255lph Fuel Pump
+ Venom Fuel Rail and Regulator
+ ACT 2600 Clutch
+ Fidanza Alum Flywheel
+ Garrett GT30R Turbo
+ Punishment Racing RACE Front-Mount Intercooler (bumper was cut to fit FMIC core and short-route piping)
+ DN Performance Polished Tubular Header
+ 3" o2 housing and Apexi N1 Exhaust w/ 40mm Tial Wastegate
+ Upgraded break pads and slotted rotors, stainless steel brake lines
+ Tokico 4-way struts with Tein springs
+ Blitz 18" 3-piece Aftermarket Wheels
+ Much, much more! PM me for a complete parts list!
In the past 4,000 miles (9 months) I've had the following maintenance done to the car via "UMSTuning"
+ August, 2014. Replaced battery. Everstart MAXX.
+ September 2014. Replaced clutch, shift fork, and pivot ball. Resurfaced flywheel. Installed ACT Extreme HD Pressure Plate w/ Street Disc. Replaced vehicle speed sensor. Replaced rear main seal. Replaced driver and passenger front axles.
+ November 2014. Had ECU refurbished, socketed, and chipped with DSMLink V3 FULL by ECMTuning.
+ February 2015. Replaced Valve Cover Gaskets, Camshaft Seals, Timing Belt, Water Pump, Oil pan, and TBelt tensioner. Resealed turbo drain. Repaired Cooling Fan Wiring. Removed AEM EMS v1 and replaced it with ECMLink v3 Full. Had conservative tune done for passing emissions.
+ March, 2015. Setup base tune to pass emissions with DSMLink v3.
Over $15,000 in upgrade and repair receipts for the vehicle. Email me for a comprehensive parts list.
Asking $5,800 for immediate local sale, but you can join the eBay bidding war with no reserve set and the starting price at $5,200 via http://r.ebay.com/4pZ2Nb
More high-res photos available at the eBay URL above!!
+ ACT 2600 Clutch
