1995 GSX occasional white smoke from idle to acceleration
Posted by dfresh702, Jun 14, 2011
Please Support VR Speed Factory
  1. dfresh702
    dfresh702 Proven Member
    35
    Joined May 10, 2011
    Springs, Colorado
    I have a 95 GSX. 6 bolt, according to receipts, was rebuilt 5-10k miles ago. Intake, exhaust, FMIC, motor mounts, 15-16 psi boost (im guessing something was done to up the boost, just dont know what) upgraded flywheel, walbro fuel pump, EGR valve removed / blocked. She runs great, all of the time. Occasionally, after idling at a red light, and as soon as i accelerate, a puff of white smoke will shoot out. It only happens during that timeframe. Under full boost, no issues, good to go. I have read many a blog on here, and some say its the valve stem seals, but only if it does it when its cold. And the turbo seals would shoot out smoke under WOT. It doesnt do it when its cold or WOT.. only after idling. I do have a CEL light on for the non-existent EGR valve. Just changed the oil, changed the valve cover gasket, flushed coolant fluids, etc. How exactly do i check for turbo shaft play? and if i upgraded to a 14B, would there have to be any tuning involved? Any suggestions?
    I forgot to mention, that i also replaced the PCV valve with a new one.
    Log in/Register to remove ads
  2. XiKeiyaZI
    XiKeiyaZI Supporting Member
    2,439
    36
    Joined Dec 28, 2008
    Dyersburg, Tennessee
    Valve Stems Leak Oil.
    Oil burns Blue.
    Coolant Burns White.
    There are a plethora of things that could cause this. What you first need to do is a compression and Leakdown test. Do your coolant Levels Drop at all over a certain amount of time? Have you ever ran hot? What does the smoke smell like? Do you smell any odd smells at all?
    We're talking pushing fluids into your combustion chambers during acceleration all the way to a cracked housing in your turbo. (Long, detailed event that's nearly unbelievable).
    My DSM:
    Loading...
  3. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    I would say blue smoke, oil. Doesnt run hot at all ever since I had the radiator flushed.. i did notice it ran a bit hot while traveling up longer than normal hills, etc.. but not anymore... compression test = get the tool, take out the spark plugs, and pressurize it right? The smoke smells verrrry bitter like... The previous owner used a synthetic oil blend.. I changed it to full synthetic.. Stupid decision? i noticed after changing to synthetic that the exhaust smelled quite a bit different. Verrrry bitter
  4. XiKeiyaZI
    2,439
    36
    Joined Dec 28, 2008
    My DSM:
    Loading...
  5. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    Thank you very much for your insight into this issue. Much appreciated.
    once those 2 tests are complete, i will post the results.
  6. XiKeiyaZI
    2,439
    36
    Joined Dec 28, 2008
    :thumb: Good man.
    My DSM:
    Loading...
  7. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    LOL ok. Im gonna stop trying to be MR MECHANIC guy, and take the car to a shop. Even though they charge 100 freaking dollars for a compression test, its probably cheaper than me blowing up my engine doing this simple task. Because if the guage said 60 PSI all the way across, either my engine is gone, which i highly highly doubt, or i didnt do it right. results tomorrow. :(
  8. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    I don't think I did it correctly.. It runs extremely smooth and strong. Could my compression be that jacked and it still runs amazing?
  9. datbmac
    datbmac Proven Member
    71
    Joined Feb 5, 2011
    Florence, South Carolina
    Not likely your car needs the right amount of compression to get the right amount of performance out of the fuel.
  10. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    I've also read smoke from exhaust sometimes means oil in the intercooler. If so, I'm willing to try to clean it. Soap and water? Nething special?
  11. iugrad92turbo
    iugrad92turbo Proven Member
    10,227
    265
    Joined May 22, 2007
    Kalamazoo, Michigan
    Soap i use kersosne, smoke like that hg, turbo, rings several things do a compression test.
    My DSM:
    Loading...
  12. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    Yah. Pray for me LOL. Taking it to a professional tomorrow. I'll post results tomorrow
  13. SD99GST
    SD99GST Proven Member
    203
    Joined Sep 6, 2008
    Oakland, California
    I had the same white smoke issue at one point, turned out it was the valve stem seals. If you do them, make sure you buy some good ones, if not the problem is likely to come back in the near future. I have heard from people that warming the car up before driving off can help maintain strong valve stem seals, but like almost everything I can hear two sides to the story.
    I would redo the compression test, look up on the site as to exactly what to do to perform this test, its really simple if you have any mechanical skills whats so ever. Good luck buddy.:hellyeah:
    My DSM:
    1999
      manual
    Loading...
  14. kowalczyk89
    kowalczyk89 Probationary Member
    Joined Apr 24, 2011
    oak lawn, Illinois
    conventional oil will give you a blueish smoke but with full synthetic it can give more of a white smoke
    My DSM:
    1999 Mitsubishi Eclipse GST
    13.500 @ 95.000 MPH
    Loading...
  15. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    Thanks for your insight.. Hopefully the guys I'm taking it to know their stuff n don't try to BS me. Thanks again man.
  16. XiKeiyaZI
    2,439
    36
    Joined Dec 28, 2008
    A compression test is pretty simple. Why not do it yourself? Did you have trouble performing it?
    My DSM:
    Loading...
  17. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    I tried myself a couple of times buy became frustrated when it read 60 psi exactly for every cylinder. I even recorded the session pointing my camera at the gauge each time to make sure I wasn't losing my mind. I also thought it could have been a faulty gauge? The MFI circuit thing is located in the cluster of fuses under the hood right? Also, the coil plug thing is very close to the injectors right?
    I tried myself a couple of times buy became frustrated when it read 60 psi exactly for every cylinder. I even recorded the session pointing my camera at the gauge each time to make sure I wasn't losing my mind. I also thought it could have been a faulty gauge? The MFI circuit thing is located in the cluster of fuses under the hood right? Also, the coil plug thing is very close to the injectors right? I watched a vid on YouTube and the guy took his injectors out. Necessary?
  18. XiKeiyaZI
    2,439
    36
    Joined Dec 28, 2008
    2G's don't have the same fuses as a 1G. Here's what you can do - After you have your plugs out and the compression tester secure in one of the cylinders...
    1 : Unplug the clip from each injector
    2 : Unplug the coil pack - This is what your spark plug wires are connected to
    3 : Get in the car and push the gas pedal to the floor
    4 : Crank over 3-5 times
    5 : Get out and record readings for that cylinder.
    My DSM:
    Loading...
  19. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    Ok will do. Question.. will not unplugging the injectors / not unplugging the coil have any effect on the compression test?
  20. XiKeiyaZI
    2,439
    36
    Joined Dec 28, 2008
    Yes. It will cause your injectors to spray fuel into your cylinder. :p Do you want to wash your cylinder walls?
    My DSM:
    Loading...
  21. dfresh702
    35
    Joined May 10, 2011
    Springs, Colorado
    Compression test results:
    130-135 across the board
    Leak down test results:
    Good across the board
    Turbo checked for leaks, none found
    White smoke remains.. Scheduling appointment to remove the head and replace anything that looks jacked up. Thanks for all the advice! Hopefully no more plumes of smoke LOL.
  22. sharkbait689
    sharkbait689 Proven Member
    77
    Joined Mar 3, 2008
    Tyler, Texas
    My car has a small oil leak and burns oil periodically (very little, not enough to fix) and on the bottom of the oil cap there will sometimes be white...stuff... where the oxygen leaked in or something. Also, after driving, burnt oil has a very distinct smell.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
