1990 Eagle Talon tsi
Posted by 91turbomirage, Apr 11, 2012
Maintenance & Repairs - Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions.
Please Support Magnus Motorsports
  1. 91turbomirage
    91turbomirage Probationary Member
    Apr 6, 2012
    6
    Anchorage, Alaska
    Ok, well i just bought a talon tsi for 1g with a rebuild motor. It is running at this time but not drivable, needs clutch and brake bleed. The owner told me he used a 93 harness for it and got it to start. The tach is not working and the ignition isn't sending power to starter to start the car thus having to jump start it. I wonder if this is because of the 93 harness and does it have to do with the coil pack? thanks
    #1
  2. StarFawkes
    StarFawkes Supporting Member
    DSM Profiles:
    Mar 27, 2012
    273
    3
    Wahiawa, Hawaii
    #2
  3. 91turbomirage
    Apr 6, 2012
    6
    Anchorage, Alaska
    I'll try fixing the tach. If it don't work and if i put in a tach would i need the coil pack? ahah nvm ill search that site.
    And for the jump start, i should've been more specific with that. But meaning i have to take a wire and manually connect it from the battery to the starter while the key is turned on for it to start. ?? should i double check the wirings or is there something about the coil pack.
    #3
  4. StarFawkes
    DSM Profiles:
    Mar 27, 2012
    273
    3
    Wahiawa, Hawaii
    Sounds like a starter solenoid/relay. Had to do that same thing with my bike a couple years ago, but I jumped from one side of the relay to the other for the same effect. Check all your connections to your starter and you could try hitting it with a rubber mallet while a friend is turning the key (no joke).
    #4
  5. 91turbomirage
    Apr 6, 2012
    6
    Anchorage, Alaska
    Will try that out when the car comes in. Being towed to my place this weekend. Thanks. and more questions in the future
    #5
  6. 19Eclipse90
    19Eclipse90 DSM Wiseman
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    Half-true. That guide is only going to help if he has a '90 harness; i.e., that connector on which to apply the fix is a '90 only item.
    If it's got a '93 harness, then it likely has a '91+ coil and PTU. In that configuration, your 1990 tachometer will not work correctly (if at all) and the easy way around it would be to swap in a '91+ tachometer.
    #6
  7. 91turbomirage
    Apr 6, 2012
    6
    Anchorage, Alaska
    i do have a 90's harness from a while ago, but not sure if the coil pack is still there. would it be easier to swap the harness? what sensors would i need to change what has been changed or would it but just a plug in thing. How much of a difference in harness is the 90's from the 93's. Or the dash harness are also the same?
    #7
  8. StarFawkes
    DSM Profiles:
    Mar 27, 2012
    273
    3
    Wahiawa, Hawaii
    You can check yours to see if it has the "tacho interface" on the back of the coil. Maybe the harness is just retrofitted for the 90s coil.
    #8
  9. iugrad92turbo
    iugrad92turbo Proven Member
    DSM Profiles:
    May 22, 2007
    10,191
    231
    Kalamazoo, Michigan
    I swapped a full harness 91 into my 92 and had some problems, some things didnt match up, got a 92 and i was all set on the 1g, pita when i got a 91 thinking it was a 92 harness.
    #9
  10. 19Eclipse90
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    You can read about the engine wiring harness differences here: http://www.dsmtuners.com/forums/articles-electrical-wiring/412841-1990-engine-control-wiring-harness.html.
    The easy way around this depends on what you have. Determine what you have and we can go from there. But based on what you've told us, swapping the tachometer is infinitely easier than swapping harnesses.
    #10
  11. 91turbomirage
    Apr 6, 2012
    6
    Anchorage, Alaska
    Cool thanks. i will take some pictures and guess ill have to find a tacho. thats the 93 cluster i have to find right.
    #11
  12. 19Eclipse90
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    It'd be any tach out of a '91-'94 turbo model.
    #12
  13. 91turbomirage
    Apr 6, 2012
    6
    Anchorage, Alaska
    ok, well i got the car, did some trouble shooting, it had 550cc injectors, scanmaster, apexi afc neo contorller, and headers. Now the guy told me he already has the 93 tach cluster in the car and it still didn't work with the 93 coil pack. Couldn't trouble shoot the starter problem so i made a custom push start button. It is running really ruff(lean) with like 40 count knocks on my scanmaster. we changed out injectors for nonturbo 90 dsm injectors ( different in ccs?) changed fuel regulator, transistor, and ran a bit better but really lean still. Seems like it needs more air. Unplugged a vac line at the i/m and received more air, thus starting better and idle a bit better. My maf is also not working? it idles really ruff when i plug it in and when i unplugged it it idles better but higher rpm. My fan isn't coming on so the engine is getting really hot to overheat mode. going to change out the fan today.
    #13
  14. iugrad92turbo
    DSM Profiles:
    May 22, 2007
    10,191
    231
    Kalamazoo, Michigan
    Sounds like a mess still, and wire related somehwhere thats the problem, where to start.
    #14
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
