15 psi Fuel system question.
Posted by gstbobby, Dec 16, 2009
  1. gstbobby
    gstbobby Proven Member
    35
    Joined Dec 14, 2009
    Trinity, North Carolina
    I am buying all kinds of parts right now for my 98 gst, im going to be running an evo 3 16g, using a MAFT and GM MAF, i was wanting to run 15 psi, i was told by a buddy of mine that i can use the stock injectors safely at 15 psi, should i upgrade the injectors and fuel pump or will i be safe?
    Log in/Register to remove ads
  2. 95blackGsTurbo
    95blackGsTurbo DSM Wiseman
    3,985
    72
    Joined Aug 10, 2003
    Cottage Grove, Minnesota
    If that is all you want I recommend getting a Walbro 190lph and I would recommend some bigger injectors. Especially since you are getting a MAF-T setup. Go with some 660's since you will have the pump and injectors to support more power if you want it while not needing an adjustable fuel pressure regulator setup. Make sure you have something to log your knock with though. And a wideband is always helpful when tuning.
    My DSM:
    1991 Eagle Talon TSi (sold)
    Street Build
    14b   manual
    1998 Eagle Talon TSi (sold)
    Street Build
    T28   manual
    Loading...
  3. gstbobby
    35
    Joined Dec 14, 2009
    im wanting my car to have as best ga mileage as i can get, its a dd, if 15 psi is not safe on stock injectors and pump ### is the highest safe boost?
  4. Nati0nalxCrisis
    Nati0nalxCrisis Proven Member
    172
    Joined Nov 18, 2009
    Mukwonago, Wisconsin
    Your gas mileage won't be affected if you tune it correctly, or it won't be affected to a significant degree, you can have 1000 CC injectors in and a 255 Wally and still get 25+ mpg, its all about boosting, if you don't boost you don't use as much gas, simple as that. Your injectors and pump will only push so much with the demand, if you get what I'm saying, if your boosting your demanding more fuel, which therefore makes the injectors push more fuel. Get it?
  5. gstbobby
    35
    Joined Dec 14, 2009
    yea i know that much but if i have the power im gonna use it LOL i was just wondering if i can use the stock stuff safely on 15 psi
    anyone know?
    please someone help! LOL
    yea just tryinto find out if the stock FP and injectors will hold 15 psi
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
