2G Finished cold air intake box
Looking good. I sent you a pm, I can weld it all up, if you aren't set on the rivets.
I am pretty close too.
9403952106
Here is the intake cover/box installed on the car, Im still fabricating a bracket to hold it down in place. Looks promising. I will give it a good polish once its all done.
Here is the finished product. I used rivets as you can see in the pictures, I think it turned out ok I just need to polish alot more. Now on to the bottom duct, I have already started!
And here is the bottom duct.
Have you ever considered using 3m casting tape? You can make your template like the piece you have, or out of foam, wrap it a few layers, then use acetone to disolve the foam. Or cut it off the form, glue it together, then add a couple more layers of casting tape and resin the result.
Can be sanded and painted, and it's pretty dirt cheap.
LINK may not work, Google "composite intake diy"
Uuhm! No not really. I was looking for something like that but could not find anything. I will look in to it. Thank you.
Hey guys its been a while but here is what I ended up doing with the bottom intake.
I think so. I haven’t done any before and after intake temps but others have and have shown significant lower intake temps. I mean if you think about it, fresh air is coming in and hot air from the engine bay is being isolated. I would like to do some pulls with and with out to log differences. Thank you for the compliment.
