Tonymwc
- 0
- Nov 4, 2018
Omaha,
Nebraska
Ok I know its been here before but Ive tried all fixes and nothing! Wont turn off unless I pull fuse or neg from battery. Sometimes the heater stays on also. Its a 1998 gsx. Tried alt fuse replaced it just incase, tried switching the relay, torn whole dash apart looking for bare wire that could be shorting, nothing! cleaned up a couple wires while I was there cause previous owner had an alarm that was removed. Took apart engine bay fuse box just to look for shorts, nothing. Not sure what to do next? *update* Talked to previous owner and he said "it started happening when his mom tried to jump start the car and her car started smoking a little" it looks as if battery cable to starter was replaced but could that have fried something? It runs ok, every now and then the cel comes on and the number three injector stops working?? I get code p0203
