Dreams Realized
5+ Year Contributor
- 356
- 160
- Jul 23, 2018
Seattle,
Washington
Hey guys I looked everywhere trying to figure out how to read the wiring diagram for the DRL ECU in the canadian spec models, and i've come up empty.
What I am trying to do is cut the wire that runs the high beams at 50% power during the day, and tap into it with my new LED setup, but I have no idea which wire does what, I took a pic of the wire colors and the wiring diagram in the haynes manual... I seem to only understand wiring if I know what the color codes mean.
I know black is ground
I assume white is neutral
I also think that the red is the main power feed wire that probably supplies full power to high beams
That leaves me with blue wire and yellow with blue dashes.
If I were to take a stab in the dark I'd guess yellow-blue is the wire I want
