RayBan GST
- 665
- 4
- Oct 21, 2007
DUBAI UAE,
Asia
can you please share some information about the AC fan speeds? how does it speed up and when? my ac is always on but i never seen the fan on high speed. when it should be on high ?
also one more question , i have connected the two fans ( ac and radiator) so they can kick together and off together and they seem to work perfectly ,however i have connected them as follows on the picture below
the last relay on the right ( lo ac fan) with relay number 4 which is ( rad fan lo) that is under the (tail lamp) they both kick well now but is this the right way or shall i connect number 2 and number 5 relays as per the vfaqs?? if you tried the vfaq way can you share if your ac fan kicks on HIGH when the ac is on?
thanks
thanks
